Results 1 to 6 of 6
Thread: 4agze problems
    Drew
    Kalamunda
    hey
    ive got a few issues with my 4agze in my 86 and im hoping someone can help because im stumped
    ok here is the background
    the motor is a 4agze afm with coils the super charger is a sc14 has a front mount and using a 4age throttle body.
    now to the problem when i go to start the car it will turn over but not start then there is a loud noise of air pressure being released.
    ive done all the simple checks like spark, timing and fuel i have also checked the afm and used another one i had to make sure it was not the problem
    here is a video of what it sounds like when it starts
    any help or things i could try would be great
    Nathan
    Lilydale
    I know youve said your checked timing, but from what i can tell from the vid, it sounds very out of time.
    have you had the motor apart/head off? one or both of the exhaust cams may be 180 degrees out, ive seen this before, and it acted very similar.
    just a thought, hard to diagnose without havin a good look! =P
    Oldschool Member
    Mar 2006
    Maybe u just fail at building sprinters drew???
    Drew
    Kalamunda
    <div class='quotetop'>QUOTE (ae86-matt @ Sep 15 2008, 11:12 PM) </div>
    yeah thats y im building yours for you and your always asking me questions
    Drew
    Kalamunda
    <div class='quotetop'>QUOTE (sprinter86 @ Sep 15 2008, 11:10 PM) </div>
    yeah timing is fine never had the head or cams out the car has been running like this for over a year with no problem i basically parked it came back a week later and no start
    Veteran Nikkojoe's Avatar
    Tom
    Sounds timing related, like its 180deg out of phase.
    I know you have checked spark, but check leads, earths, reset cas etc.
    Check also if there is power to injectors and if the ecu is getting power to it.
  1. 4agze CAS signal problems with Haltech e8
    By lloydious86 in forum Technical - Questions
    Last Post: 4th October 2009, 06:22 PM
  2. problems
    By wide s13 in forum Technical - Questions
    Last Post: 24th May 2008, 11:48 AM
  3. problems
    By slidekid in forum Technical - Questions
    Last Post: 23rd May 2008, 04:06 PM
  4. 4agze boost problems
    By samuek in forum Technical - Questions
    Last Post: 29th April 2008, 04:42 PM
  5. 4agze conversion problems
    By AE86.cn in forum General Topics (No Technical Questions)
    Last Post: 13th March 2006, 04:10 PM
