Results 1 to 8 of 8
Thread: safe to turbo stock bigport?
    Senior Member sld sho's Avatar
    Sep 2010
    Ozman
    Broadmeadows
    Default safe to turbo stock bigport?
    hey guys just wondering if it is safe to turbo a stock bigport engine and run max 7-8psi boost ?
    any body had any expereince with this?
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    i wouldnt say safe, but it will work okay
    ~KEEP DRIFTING FUN~
    Has been done a few times and achieved around 120kw at the wheels. Like any build get your tune right and it'll be ok
    Veteran AJPS's Avatar
    Lonsdale
    dudes in NZ were running 15 psi on 'stock' big ports
    i think up to 10psi with a good tune and good cooling system etc you will be fine
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    i wouldn't go past 7psi....... Proberley better off spending the money on making a strong NA motor...... rather than having a turbo motor that you need to baby........
    What is the car to be used for?
    Sep 2010
    Ozman
    Broadmeadows
    just a weekend car i can take to the track a few times a year
    JoJo
    ACT
    Tuggeranong
    I wouldn't do it. Go either a strong NA
    or if you really want turbo, get a 4AGZE block.... They are pretty cheap if you are buying a basic block, you can use some of your current parts to complete it....
    Christian
    Burnside
    The simple answer is yes it is safe. One thing that you need to bare in mind is that 90% of the time it’s not at boost that kills the motor, thinks like oil pressure and temperature, the quality of the fuel you run, coolant temp and tune. These things all become more and more important as boost pressure is increased (exactly the same applies for tuned NA motors). If you take care of the motor and address all these issues the engine should last years especially if you only run 7psi
  1. best exhaust setup for stock bigport
    By s13 james in forum Technical - Questions
    Last Post: 17th October 2012, 08:48 PM
  2. cams in a stock bigport?worth while?
    Last Post: 16th October 2012, 11:09 AM
  3. Turbo Bigport
    By BLIPAE86 in forum Technical - Questions
    Last Post: 15th March 2011, 09:45 PM
  4. Replies: 4
    Last Post: 2nd January 2011, 10:30 PM
  5. stock fwd bigport manifold.
    By HiLtOn in forum Cars or Parts Wanted
    Last Post: 13th March 2008, 12:34 AM
