From the start....
Well get this..... My 86 was tuned at Gentech (Canberra) 3-4 years ago. Back then, it had a shitty fuel pump, 365c injectors, and was tuned at 162rwkw, but rev limited to 6200rpm cause it was starting to lean out after that...........
Last year, it was put on the ESP (Canberra) dyno at a dyno day. It made 147rwkw, but was running lean, and they only would run it once..........
Since then (6 months ago), I fitted a new fuel system, consisting of, custom swirl pot inside tank, bosch 910 pump (400hp rated) and surge tank........
This week, I took my car back to Gentech, for them to fit 440c injectors and tune it to suit (ie more fuel delivery and raise the rev limiter from 6200 to where it should be).... I got it back yesterday.. It only made 141rwkw and he didn't raise the rev limiter any higher cause it wasn't making any more power after that....... I am annoyed.....
Is this poor tuning, or a reflection of my setup?
Specs of my motor:
ENGINE: 10,000kms approx since rebuild
Late model Smallport 4AGZE, T25G Turbo, RaceTec manifold, 440c Injectors (7MGTE), Microtech LT 10s (with hand controller), Front mount Intercooler, Golpher Aluminium Race type radiator, 9 row oil cooler with Speedflow fittings, Blitz Blow Off, 3" dump pipe, Full 2 and half inch Exhaust system, Alloy catch can, some braided lines with Speedflow fittings, 3A Racing Pod filter
FUEL SYSTEM:
Custom modified fuel tank with intank swirl pot (from 45aken's Lemon 86) , VL lift pump, 1.5L undercar surge tank, Bosch 910 main pump (380hp) and bigger undercar fuel line.
