Just after a bit of help fellas regarding the TVIS.
Basically, I have only ever really had/fitted smallport 4age's, so I am a bit of a noob when it comes to the bigports TVIS system.
The story is, While I am building my N/A hi-comp forged motor, I want to put a standard 4age in my new KE70 in the meantime. As I have a shed full of 4age parts and a few 4AGE motors etc, I should have everything there to make it happen. Except for a TVIS system. I do have a TVIS manifold, but it is non-functional as it has had the guts ripped out.
The parts I will be using are:
Standard JDM Bigport
JDM RWD manifold and TB
Microtech LT10s with custom loom (came out of a 4AGE AE71)
Reading on the Billzilla (Bill Sherwood) website, it says the Tvis is ECU controlled.
Since I am running a aftermarket ECU, does this mean that I dont need the TVIS system at all? Will the tuned aftermarket ECU make up for what the TVIS does on a standard setup?
As I said, I have never had a bigport (TVIS) motor before, so it's all new to me.
Also while I am here, What do people usually do with the throttle bodys? I am thinking of just making up a plate and gasket and blanking off the bottom of the throttle body. Yes? No?
