Well, do you have spark?
Does the CAS work all good? Probed it on an oscilloscope?
Just hooked up my loom everything seems to be working fine but still wont start, check injector pulse and there doesnt seem to be any, anyone got some help?,![]()
Yep spark is all good, no idea what an ascilloscope is lol
Have you earthed the ecu loom (brown wires that bolt to intake manifold)? I assume there is a good earth on the engine (ie thick cable from the block or head to the body, and a couple of other smaller ones).
Traced back the injector power feed wires and made sure they are getting 12v on ignition?
Yep the brown wires are earthed, and indeed I do have a thick earth strap from the block to the battery, and another one from the body to the battery... And the injector wires are getting 12v
