No sparkie out there that can answer this ?
Hi guys , A few questions from a wiring nob.
I have a 2nd hand JDM LOOM ( PREVIOULY FITTED TO A ADM AE86 ) . I have plugged in all the obvious engine conections and following the Big Port wiring guide I have done the altinator and coil mods ( tested each , all ok ) .
My question is thus, as I can find no mods to this loom that have been do before ( was fit to a ADM bigport by previous owner ) do I still need to do the following mods ---------------------------
1. POWER TO INJECTORS ?
2. ECU POWER ?
This is the big port witing guide instructions ---
-On 14 pin plug, Pin 7 (+B1) and Pin 14 (+B ) can be connected together, and go to ignition (or can come off a relay you used for coil power)
-On 14 pin plug, Pin 6 (Batt) goes to constant battery 12V source (ie wire straight from positive terminal on your battery if you want, fused - 7.5amp should be the max you need). There is a battery power wire found in the passenger side kick panel wiring junction box (big thick white wire). Tap into this instead of running an ugly wire through your engine bay.I have done this bit.
For fail safe starting, you may also need to give power to injectors (Yellow wire found on 10Pin plug, Pin 10 (BF)) by joining a wire into the yellow wire and giving it 12V on iginition (again, use the same relay that you may have used for coil, but might be drawing too much current).
If so then when it instructs for me to connect to black /orange trigger wire for power to do injectors (1) and ecu power up (2) . Does it mean just connect to that wire (black /orange ) , our does it mean repeat the same fused relay mods that I did when I did the coil wiring.
Hope this makes sence .
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
When I wrote that I meant use the black orange wire as a trigger for a separate relay to make a secondary 12v ignition source. You can use this secondary source to power the injectors and give power to the ecu.
However, if you want to be extremely neat, the engine bay fuse box on an 86 has a spot for efi main relay. You need to get the factory fitting relay and then work out which is the output pin under the fuse box.
Further more if the loom is a zenki jdm loom, the injector power wire is located on the middle firewall plug along with starter, coil power, reverse lights, water temp, and oil pressure.
Thank you for that , I was on the right track , now you have confirmed . Thanks Again .
Right guys the wiring nob can't get the car to start.... I have done the wire up with some sucess, but for the life of me I can not get power from the coil to the distrubutor.
On the sucess side ----- ECU has memory power ---- Ecu has ign power via relay set up ----- injectors have power via relay ----- ciol has power via relay , fuel pump works when car is turning over. Can hear the injectors click. But off course all that is of no use if I can not get power to the distributor.
On ignition I have power at both + and - posts on the coil. I have inspected all the earths ,checked the fuses , checked the connections they all seem ok. I have swapped both the coil and the ignitor off a running AE82 4AGE 16 V , still no spark . I direct wired batt + to coil + --- still no spark . Attached a timing light to no 1 no light flash.
Although every time I try to start the car I get one spark , a cough at the intake , but as I continue to turn it over it all goes dead in the spark department.
I am not sure what to try next any ideas from people in the know I would be very greatfulL . Rebuilt this car for my son , new paint etc etc and this and rego are all that is stopping this project from living.
you have done everything right, trust me.
I had this problem once too. man......what did i do to fix it.......it was a while ago.
all the things you have done above are 100% correct. it should run, ill have to think.......
Check your earths! Main earths being:
-Thick engine earth from block to body (and smaller secondary ones)
-Make sure igniter is bolted down and earthed well<<< this could be your issue (i had a poor earth once and it did exactly as you said)
-Make sure loom is earthed on intake manifold
Still no start !!!!!!!!!!!!!! Bloody frustrating , Car now has plenty of good earths --- 2 x block to body , head to body , loom to inlet manifold , coil/igniter to body x 2 , body to neg battery , all relays earthed to neg batt. Ecu to body etc etc etc .
Turn it to ignition and I have power at both + and - posts on the coil and every thing else is a go . But soon as I turn to start , the car gives one spark to distributor, a cough at the intake , then nothing, as I continue to turn it over it all goes dead in the spark department.
If anyone has had this problem and fixed it please let me know.
Check your leads, including coil lead.
Leads are new ( no garantee I know ) but I tried them on the AE82 and they worked fine . I am no electrician but even thou the big -- 3 ( ECU , COIL , INjECTORS ) are on seperate relays they all have been taken off the black/orange wire that was connected to the previous set up on the 4a. Could it be that there is a voltage drop on start ----- and I am not getting the full 12v at that moment ??????????????? . Might check that out tomorrow . If so I will have to find a 2nd power out let on ignition ( black/orange ) , but not on this side of the loom I expect . What do you think , plauseable or am I barking up the wrong tree .
