Results 1 to 6 of 6
Thread: need help with ecu wiring
    Mar 2011
    pat
    bundoora
    Default need help with ecu wiring
    i have a jdm wiring loom for my jdm 16v bigport my 10 and 18 pin plugs fit in my ecu but the 14pin plug doesnt. just wondering if anyone could help me with a wiring diagram. i have searched and searched but no luck i couldnt find anything that matches up with the colours on my loom. ill put up some picture for guys to see
ID:	21638   Click image for larger version.
ID:	21639   Click image for larger version.
    Veteran Nikkojoe's Avatar
    Tom
    Read this thread.
    Mar 2011
    Ali
    Is the ECU JDM also?
    Mar 2011
    pat
    bundoora
    yer ecu and loom are both out of a jdm rwd 16v big port
    Veteran slide86's Avatar
    Huw
    Hills
    Did you read that link????????
    It clearly states that plug has nothing to do with the ecu as I have stated in the thread
    Mar 2011
    Ali
    I think SV21 Camry ECU 14pin plug is the same plug as on ADM AE82 Bigport ECU.
    Might pay to visit the local wreckors, take your ECU and try it.
    If it fits, strip it back to the fuse box take everything with it.
    The colours might differ, but if you use the JDM wire diagram you'll be able to work it out.
    Try this
    Its the 84-85 pin outs
  1. 4agze wiring and ECU
    By keiichi in forum Technical - Questions
    Last Post: 12th December 2010, 10:06 PM
  2. SR20 redtop ECU WIRING
    Last Post: 28th March 2010, 12:35 AM
  3. 4A-GE smallport ECU wiring
    By stahlz_ae86 in forum Technical - Questions
    Last Post: 17th May 2009, 08:05 PM
  4. 4age ecu wiring
    By levin_boi in forum Technical - Questions
    Last Post: 21st April 2006, 09:45 PM
