i win the prize
hey guys just been trying 2 find out if there is a tacho wire from the 4agze ecu is a dual coil pack version/map sensored ecu i need 2 wire up my 5 inch tacho and cant find out which wire from the ecu sends a tacho signal
i win the prize
sick 1 now just hopefully ill be able 2 find it swear there was some bad bad wiring done when the guys did the engine conversion before me
Ecu does not send a tacho signal. It comes off the igniter plug.
It's the 6pin plug on the igniter on the bottom left corner (next to the blank pin) if you look into the plug. It should be a black wire, with either brown or silver dots.
hey ive got a ecu pinout and it has 3 spots where the igniter comes out on the 26 pin plug can splice into there
