Results 1 to 10 of 10
Thread: part number for 4AGE bluetop TPS?
    Member extra_anchovy's Avatar
    Nov 2010
    Damian
    Gawler
    Default part number for 4AGE bluetop TPS?
    my cars been having this ongoing problem where it doesn't want to accelerate when you hit the throttle it just stutters. its really annoying to drive, almost unbearable. anyway I suspect that it might have something to do with the TPS. when I replaced it the new one had a different part number printed on it then the old one so figure maybe its running like crap because its running the wrong TPS. so my question for someone with an AE86 bluetop 4AGE that runs good - what is the part number of your TPS?
    Veteran timbo's Avatar
    Tim?
    Wild West
    toyodiy.com
    Veteran Nikkojoe's Avatar
    Tom
    there are many tps part no.'s.....
    Pretty much any 4a tps is compatible, all have the same output. Even if you had a round plug you could change it to a square plug and it will work fine.
    If you want to eliminate tps, unplug it and take it for a drive. If it improves then you might need to set it up properly, or if it is setup correctly then you might have an issue elsewhere in the wiring.
    Nov 2010
    Damian
    Gawler
    i used toyodiy to order this one and somehow got one with a different part number, and it looks different. how would I locate an issue in the wiring? its been to an electricians hundreds of times and they haven't been able to locate the cause. whenever they readjust the tps it drives good for a week, then the problem slowly creeps in and after the 2nd week it's pretty much completely fucked again
    Aug 2010
    Geoff
    mt dandenong
    i've personally found that FWD and RWD ones are different. i helped a friend with the same issue and ended up having to swap entire throttle bodys because of the incompatibility between fwd and rwd versions.
    so if you cant find the part number, just buy another assembly.
    Tom
    Yeah should have mentioned, JDM and ADM are different (fwd and rwd can be the same, ie ae82 fxgt and ae86), but im talking about electrical compatibility.
    You also dont need to change the entire throttle body, only the wing which activates the tps.
    Aug 2010
    Geoff
    mt dandenong
    in reference to the wing which activates the tps, jdm sits vertically and adm sits horizontally right?
    Jay
    I've got a nos big port tps kicking around will have a look if I can find it and get the part number when I'm
    More sober
    Rust is a way of life
    Tom
    Yeah correct. Don't know why they changed it but its an adm/jdm thing.
    Simple to fix providing you have both throttle bodies (or the wing), just a 10mm nut hold it on.
    Nov 2010
    Damian
    Gawler
    you mean a throttle body assembly? that wouldn't be pretty difficult to find one.
    after the last time I been to the electrician he said it could be the MAP sensor as it's the only thing that doesn't check out. just tried toyota spare parts and they cost over $400! does anyone know if there are any cheaper aftermarket ones available?
  1. 4age rwd alternator part number
    By Deeken in forum Technical - Questions
    Last Post: 30th September 2011, 08:34 PM
  2. 4AGE Distributor Part Number
    By Victim in forum Technical - Questions
    Last Post: 2nd June 2010, 10:31 PM
  3. JDM 4age TPS part number
    By KE70 in forum Technical - Questions
    Last Post: 11th March 2009, 03:26 PM
  4. Need Part Number
    By Kamikaze in forum Technical - Questions
    Last Post: 8th August 2008, 04:47 PM
  5. 20v tps part number...
    By shelldrake in forum Technical - Questions
    Last Post: 28th December 2007, 08:35 PM
