Keen for 7age but im in sa! 5098 also want the RCA's! What size are they?
hey guys,
i have a whole heap of stuff to sell. need to sell so i can get my missus and son back to perth.
prices do not include delivery. would prefer local buyer as 60-70 hour weeks means not much time for posting. im in yokine 6060 WA
will accept REASONABLE offers. stupid offers will receive stupid (possibly insulting) reply.
can take pictures for genuine buyers, though most stuff is obvious what it looks like.
pm me if interested. if i dont reply straight away its cause im busy at work. but i will reply
1. t series diff - 4.77 weir eng. final drive, kaaz 2way lsd, fresh bearings, fresh axle bearings and seals, fresh brakes, solid pinion spacer (instead of collapsable).
only done 1500km $1400
2. whiteline rear adjustable sway bar - only done 1500km. $150
3. t3 adjustable panhard rod - only done 1500km. sold
4. t3 roll centre adjusters - modded slightly to fit bc coilovers but still fit anything else. $80
5. 7age - freshly built 7age. runs 16v bigport head that has had cast marks cleaned up, head serviced etc. freshly built with new bearings and new acl pistons, rings etc.
t3 adjustable cam gears already dialed in. has strengthened rods with arp2000 bolts. all new seals and gaskets. comes with ae86 rwd manifold. 7age skimmed flywheel.
comes with alternator, new water pump. will also come with jdm ae86 engine harness sold
6. stock 4age - no manifolds, leaking water pump. bigport. $150
7. ae86 subframe - 4age subframe suit ke. $100
8. t3 adjustable lower control arms - these are the solid ones, not the weld on kit, less than 1000km done sold
9. jdm ae86 4age ecu - $100
10.ae86 front hubs - new bearings and seals less than 1000km done sold
11.jdm front brakes - comes with backing plate, new rotors, new bendix pads. done less than 1000km sold
12.bride seat rail - ae86 bride seat rail modded to suit ae71. $170
13.t-50 - shifts well. has new t3 selector bushes thru it. from ae71. done 120,000km almost all by grandma $250
14.5 inch blue dildo knob - clear bubbly blue sold
15.tailshaft - suit ae71 t-50 to t series diff $200
16.clutch - exedy heavy duty clutch supplied by t3. 5 puk clutch with heavy duty pressure plate. best clutch i have ever used in an 86
done less than 1000km $250
17.intank fuel pump - is a ae102r fuel pump made to fit ae71 bracket. used as pickup but enough pressure to run a 4age. $50
18.cusco lowered engine mounts - still in box sold
19.extractors - 4-2-1 extactors in stainless. really nicely made, no cracks. not sure of name brand but definitely noticed difference on my 4age sold
20.i am posting this on behalf of my friend.
sr20de engine package to suit ke70/ae71 - comes with everything need to get the sr into the car. new *e7* radiator with top outlet swapped to suit the sr. subframe already
welded to mount the sr. sr20de done 115000km. wiring harness and ecu. rb20 gearbox mounted up to a sr bellhousing. tailshaft for box to t series diff.
this sort of thing is pretty hard to ship so would prefer pickup only but if needs be will ship if courier organised. currently it is all in a ke70 which i used at the WA matsuri
he is chasing $1750 for everything
21. steering rack - comes with ajps lock spacer, new rack ends, new tie rod ends, new boots. been in the car for 2 events only. $200
have more stuff but cant think at the moment.
will post later
Originally posted by AJPS
"I would of given a thumbs up, but my face was in some super models breasts covered with coke"
the rcas are the t3 items. from memory 35mm
i would be ok to send the 7age to SA if you organised a courier. i can wrap it and get it ready to be picked up
Ill look into it and let u know asap
Check ur pm's
Panhard and hubs sold to me:-)
ROYAL GARAGE NEWCASTLE
PM Sent Re Seat Rail
all pm's replied
what size is the clutch plate? 200mm?
Need to replace pressure plate on my current clutch (exedy hd with 4puk) so i might get this before it ruins the current throwout bearing...
I'll have to get it when i get back from over east next week....
there is one guy keen on it. he said hed pay on tuesday for it. if he doesnt come thru on tuesday its all yours tom
p.s hurry up and finish your car already
