Results 1 to 10 of 12
Thread: Latest FT86 Info, Totally stolen from somewhere else.
    Steve
    Default Latest FT86 Info, Totally stolen from somewhere else.
ID:	22369Click image for larger version.
ID:	22370Click image for larger version.
ID:	22371Scans from a training manual.
    Power/weight:
    HP: 147kw (200ps) / 200hp @7000rpm
    Torque: 205nm (151 lb/ft) @ 6600rpm
    Weight:
    2662 ponds (1210kg) for base manual (~ 2580 lbs dry weight)
    2706 pounds for higher trim manual
    Columns:
    First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
    Top Section:
    The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight.
    Top spec manual is 1230kg, auto is 1250kg.
    Low spec manual is 1210kg, auto is 1230kg.
    Then its turning radius.
    High spec rides on 17" wheels and low spec on 16.
    Second Section:
    This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks premium unleaded and 50L fuel tank.
    Fuel consumption base model:
    13 km/l
    30.58 mpg
    49.21 kmg
    Fuel consumption top model:
    12.4 km/l
    29.17 mpg
    46.94 kmg
    Third Section:
    This section is front engine/rear drive, transmission type, suspension type, brake then tyre size.
    High spec brakes: ventilated discs front and rear.
    Low spec brakes: ventilated front, non ventilated rear.
    Last Section:
    Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
    More update:
    Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start".
    MORE THINGS OF NOTE:
    Strut front, double wishbone rear suspension
    Base halogens, optional HIDs on base trim, standard HIDs on high trim
    LSD on all MT cars
    Stability control standard
    Only 2 speaker audio on base car
    High Spec:
    Has "high-quality fabric" (上級ファブリック).
    Option for leather heated seats with Alcantara inserts.
    Steel door sill insert / scuff plate (ステンレス製ドアスカッフプレート)
    Interior metallic door handle inserts
    Carbon fiber center console trim
    Door courtesy light
    Knee pad on console
    The "Customize Grade" at the bottom is interesting:
    the "customize grade" bare bones model is 1190 kg !!
    Unpainted bumper
    16 steelies (says ornament-included, guessing it includes the logo)
    plastic steering wheel
    NO A/C (only a heater)
    Power door locks
    Sunvisor (no vanity mirror)
    No speakers
    the car in fact does require premium unleaded gas (無鉛プレミアム)
    the rear seat is one piece and is foldable (一体可動式)
    did anyone mention that the high spec model comes with a digital speedo and tachometer? (デジタルスピードメーター revメーター)
    Veteran AJPS's Avatar
    Lonsdale
    147kw and 1190kg....
    its not that much better than 96 and 920
    where is the turbo one?
    at least the handbrake is in the correct spot for the rhd model
    Steve
    Dare i say no turbo for Toyota, that will be Subies domain id say.
    There was talk/suggestions of a R-Type with Brembo's, roll cage, no back seat etc, but as usual, ill wait for what Toyota say's in the coming weeks.
    For me so far im liking it.
    And id dare say ill get 1 "IF" it does 0-100 6.0-6.2secs, under 15secs 1/4mile and under $30,000, BWHAHAHahhahahahahahaha who am i kidding, it'll never happen.
    Lonsdale
    yeah im still keen
    Steve
    Me too, and i might even venture into my local dealer without a cold sweat beading off my forehead, all weak in the knee's as i usually do.
    Veteran stahlz_ae86's Avatar
    Paul
    Steve
    There actually 2, well 3 if you consider what Keichii supposedly said, reviews, all around May this year.
    I forget where the other 1 is.
    Junior Member orange's Avatar
    Nov 2009
    orange
    What about whacking on an Aurion blower?
    Veteran timbo's Avatar
    Tim?
    Wild West
    Those power figures are fairly disappointing... Wasn't the Beams 3SGE around the same mark?
    Veteran Nikkojoe's Avatar
    Tom
    Yes the power figures were about the same for the 3sge. However, emissions today compared to 10years ago are much more restrictive. Its been said that the engine was achieving ~230hp but emissions targets meant this figure was reduced.
  1. My Latest Daily
    By 44GTE in forum AE86 Owners Forums
    Last Post: 23rd October 2014, 08:57 PM
  2. Latest FT86 Spy Pics
    By Nicko in forum Info / Pics & Discussion
    Last Post: 16th June 2011, 02:41 PM
  3. Stolen Items. Reward for any vital info!
    By buddyparts in forum Adelaide & SA Events and Discussion
    Last Post: 29th October 2010, 01:38 PM
  4. Totally jinxed myself!
    By Dillon Mac in forum General Topics (No Technical Questions)
    Last Post: 17th July 2007, 09:27 PM
