Results 1 to 6 of 6
Thread: ZE tensioner for bigger pulley?
    Jason
    Gold Coast
    Default ZE tensioner for bigger pulley?
    What do you guys use as a tensioner when using a nevo crank pulley or the like? the stock tensioner is too close to the crank pulley and chews belts.
    cheers, jase
    Veteran Nikkojoe's Avatar
    Tom
    I used a hyundai EP016 (nuline part number) pulley. Go to an auto shop that stocks nuline products and get them to order that pulley. I used it with a 178mm crank pulley.
    Jason
    Gold Coast
    ah, thanks mate. will look into it.
    Jason
    Gold Coast
    That doesnt fit at all, the internal hole diameter is to big and the bearing is so wide that only a bit of thread sticks out to screw the nut on.
    So still on the hunt.
    Tom
    That fitted mine perfect, and i still had plenty of thread to bolt it down. The internal diameter was the same size as my standard tensioner. Make sure you didn't find the EP015 (i think) part as they are what you might be confused with...
    Edit, here is a pic of it on my gze:
    go get a 4ag timing belt idler, cut the tabs off (optional haha) and flip it around. you have yourself a perfect idler.
  1. 4age/ze lightened pulley kit
    By aus_86 in forum Cars or Parts Wanted
    Last Post: 23rd May 2010, 01:01 PM
  2. S/C tensioner pulley
    By ae86 slide in forum Cars or Parts Wanted
    Last Post: 2nd June 2009, 01:48 PM
  3. WTB: 4AGZE tensioner pulley
    By Gilly in forum Cars or Parts Wanted
    Last Post: 19th September 2008, 09:03 PM
  4. 4agze tensioner pulley
    By nvy-412 in forum Technical - Questions
    Last Post: 18th August 2008, 08:28 PM
  5. WTB: Oversized 4agze Crank Pulley (bigger than 170mm)
    By Nikkojoe in forum Cars or Parts Wanted
    Last Post: 5th December 2007, 09:44 PM
