Results 1 to 10 of 12
Thread: same dyno different diff ratios
    Glenn
    North Ringwood
    Default same dyno different diff ratios
    been tuning my new motor with E85 and 14.5 to 1 comp and it made 204kws at 9000 rpm diff ratio is 4.3 and 205 x50 x15 rims about 584mm dia
    went back last week end same motor but 4.55 ratio and also changed the tyres to 225 x50 x15 or 603mm power is now 176 kws
    but also at 100 kays with 4.3 and 205 tyres revs were 4250 rpm in 4th
    with 4.55 and 225 tyres revs are 4370 ,so a little more
    so most dyno dynamics change as soon as you change little things
    Moderator Sam-Q's Avatar
    Endeavour Hills
    shouldn't make a difference unless you used a different ramp rate. Are you sure the atmospheric compensation isn't set wrong?
    I wouldn't panic about the numbers... They are just that and depending on the temps etc. one day you'll get say 200, the very next it'll output 150.
    Never been a fan of dyno outputs, given the variance. You'll find the "performance workshops" readings are higher after they work on your car.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I hear so much about dyno differances and numbers that they put out..
    I am no dyno expert, but my 4AGTE has dyno'ed pretty much the same, on 3 differant dynos at 3 differant workshops..... 152kw, 148kw, 150kw
    Timmy D
    North
    ever had this on a main line glen?
    JJ
    Glenn
    North Ringwood
    std motor made 156 on a dyno dynamics and made 154.7 on a mainline ,same tyres and same diff ratio but with 48mm quads plus 2stage injection and race pipes
    Glenn
    North Ringwood
    maxhag on the 3 dynos you used 4kilowatts difference is ok ,but i cant except 204 down to 176 with just different diffratio and different size tyres
    also same ramp rate and same temps on the day ,we even check the barametric ,and humity as well .we think it must be as the car goes up on the dyno it has different load with different diff ratio and also bigger tyres
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Wow, that's a huge difference. Could it have been strapped down differently? Iirc that can make a big difference.
    Andrew
    Glenn
    North Ringwood
    talked to my mate at motec ,as i have gone up to wider and bigger wheels ,this now creates more friction on the rollers and a lower reading same with diff ratio as well ,they all add to different readings
    Mar 2011
    Dave
    SE suburbs
    wider tyres will create more drag, causing a lower reading... but not a cause a drop as big as yours. There's a couple things to take into account, firstly the fact the dyno sessions weren't on the same day (so that can cause different readings straight off the bat!), then there's other factors.
    IMO, it's the larger diameter tyres that is causing a majority of the loss. Warning, the following has some maths involved...
    Lets simplify the wheel & tyre down to a round solid wheel. It has a thing called the Polar Moment of Inertia (PM). Simply put it's the wheel's resistance to being rotated. The formula for PM = 1/2 x mass x radius^2. Increasing the mass will increase the PM, but not as drastic as increasing the radius. You have done both (larger tyres will be both heavier and larger in diameter). Thus, increasing the wheel's resistance to turn.
    Now when you accelerate a wheel, that takes HP, which is worked out from torque (this is how inertia style dyno's work). The torque (T) required to accelerate the wheel is:
    T = (PM x "RPM per second") / 9.551. "RPM per second" is the rate of acceleration.
    From that we can work out horsepower (HP) as, HP = (T x RPM) / 5252 <-- This is why inertia dyno graphs almost always have HP and Tq graphs crossing at 5252rpm.
    So....... what i'm saying is, the larger the wheel, the larger the Polar Moment of Inertia, the more is resists rotation (slower to speed up), and thus requires more energy to accelerate up to speed.. regardless of if it's on a dyno, or driving down the road. By putting larger diameter wheels & tyres on it, it will cost you HP. No if's, but's or maybe's. It's physics.
    The diff ratio swap should have given you a *little* more power at the wheels, for the same reason running a car on the dyno in 3rd gear always makes more power than in 4th. The motor has more mechanical leverage (shorter gearing) to act against the rollers - i know this from my own experiences with my own cars & bikes on various dynos. Yes dyno's can run correction and all that to accommodate this, but they always read higher when a shorter gear is used.
    At the end of the day, it doesn't really matter what the dyno says if you have had 2 different runs on 2 different days. Dyno repeatability is always a big problem, regardless of what modes and/or corrections are run. The only way to tell is to have a dyno session where you change ONE thing at a time, and kept the conditions as close to identical as possible.
    In your situation, you have multiple factors causing a lower reading: 1) wider tyres = more drag, 2) larger wheels require more power to accelerate, and 3) the conditions on the day may have been less suitable than on the day you made more power.
  1. T18 Diff Gear Ratios
    By the_van_can in forum Technical - Questions
    Last Post: 17th January 2011, 10:01 PM
  2. Info on F series diff ratios above 4.3
  3. E seies diff ratios
    By Jason Clements in forum Cars or Parts Wanted
    Last Post: 5th February 2009, 06:46 AM
  4. Diff ratios
    By AE86_4life in forum Technical - Questions
    Last Post: 7th February 2008, 04:04 PM
  5. diff ratios?
    By not for show in forum Technical - Questions
    Last Post: 19th October 2006, 02:06 PM
