Results 1 to 6 of 6
Thread: Engine overheating and smelling of maple syrup
    Member camkore's Avatar
    Cameron
    Liverpool
    Default Engine overheating and smelling of maple syrup
    Alright well on the way home from work.
    Started to smell maple syrup about 10mins out from home.
    Notice temperature gauge 2 mins from home is almost on high.
    Get home an inspect engine bay.
    Steam coming from a Crack/split in the hose just right of the clutch reservoir, right behind where the plenum (spelling?) is.
    I didn't get a chance to take a pic and I haven't done anything since as I am in cairns on a holiday (good start I know)
    Checked the brakes, oil and clutch levels later on that night when she cooled and they were all ok.
    Could see a shiny liquid running from under car into drain as it was rainy at the time.
    I searched the smell online and it was saying it could be fin a couple of places and has to do with the coolant?
    Has this happened to you guys before? Or know of what I am talking about?
    Any help would be appreciated.
    Cheers Cameron
    Mark
    pretty sure that smell is burning coolant. Does the exhaust blow white smoke?
    Could be a head gasket. Or more likely that hose is split and leaking coolant everywhere, hence high temps and smell. By shiny liquid do you mean liquid with an oil slick on it?
    Also you mention the brake, clutch and oil levels but did you check the coolant level?
    Noooob
    Toyota coolant is red so it adds up it is likely to be that, and more specifically a heater hose.
    Cameron
    Liverpool
    I didn't check the coolant level which could most likely show me what is up.
    Car doesn't blow any white smoke which I suppose is a good thing.
    I could see something ontop of the water like an oil.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Most likely Hose needs replacement and the coolent is just picking up greasy oils when running off your engine block etc..
    Check you engine oil, make sure it's still oil and not a mix of oil and coolent, you will know something is up if it doesn't look like oil
    dose
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    just sounds like the smell is coolant.
    Easy to test your senses dude, just chuck some coolant on something really hot and see if it's the same smell when it steams off..... Pretty simple/basic experiment
  1. ca overheating help me.
    By slipps in forum Technical - Questions
    Last Post: 23rd May 2008, 08:56 PM
  2. Engine Overheating
    By fozz in forum Technical - Questions
    Last Post: 17th September 2007, 02:03 PM
  3. McDonald s pancake syrup
    By Gilly in forum Offtopic Discussions
    Last Post: 7th May 2007, 10:02 PM
  4. Overheating 20v
    By _matt in forum Technical - Questions
    Last Post: 11th November 2006, 10:08 AM
