Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Removing bastard lug nut
  1. #11
    Big pair of quality vice grips will get that off....
  2. #12
    Veteran stahlz_ae86's Avatar
    Paul
    Or an allen key you don't care about cut a piece of hex key 30mm long (has to be oversize) bash it in then use socket to remove maybe...
    When metric cap screws are flogged out at work we just use the next size up allen key from the imperial set, tap it in with a hammer then most of the time they undo.
  3. #13
    Apr 2010
    Mike
    chisel into the centre then turn it with a shifter
  4. #14
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I had the same style nuts do the same thing. After trying things mentioned already, I eventually made it so i could bash a socket tightly over the outside of the nut and turn it that way (18mm socket from memory)
  5. #15
    Senior Member macca1590's Avatar
    Central Qld
    if you handy with a welder you could just weld another nut to it, and if you do a good job you can even use it again haha
  1. [FS] BLOX Extended Lug Nuts (20x 1.25) -NSW
    By PKPAT in forum Car Parts For Sale
    Last Post: 26th December 2011, 02:33 PM
  2. Wheel lug inserts
    By grey_nomad in forum Cars or Parts Wanted
    Last Post: 25th February 2010, 06:33 PM
  3. rounded lug nut, and engine noise.
    By Ade_Mc in forum Technical - Questions
    Last Post: 25th February 2010, 04:35 PM
  4. lug/tuner nuts....
    By DRFT - 86 in forum Car Parts For Sale
    Last Post: 8th September 2008, 04:48 PM
  5. My whore-faced bastard
    By white nike in forum AE86 Owners Forums
    Last Post: 19th December 2005, 05:59 PM
