bump
Hi,
please check it out. i am open to offers. i have owned this car since 2004 and i am the second owner wasn't in good shape when i got it as the lady just used it to get around and didn't care at all about it. the chassis has 320,00 km on it but is sweet as and straight. Has mod plate for the N/A engine, half cage and interior
Engine:
16v Big-port with about (160,000 km s) running hks piggy back, just using map and tps for tune with no o2 sensor. Blows no smoke at all.
Turbo with high-mount manifold custom, 38mm external waste gate (6psi spring), 3' dump pipe with a new straight threw 2.5' exhaust has a 3a racing muffler (6' main with 4.5' tip)
Davis Craig electric water pump, thermo fan with switch.
rwd genuine Toyota water pump gear
Jdm rwd inlet manifold
new battery
fmic with 50mm piping very neat with no bov
bosh 044 full pump in-line under car
new coil
only one little oil leak from the sump gasket to leaves like 1 drop a week if that.
was tuned in QLD by road and track a while ago but he didn't tell me what power was made
Dyno tune belconnen tuned this engine with no turbo but 20v throttle bodies and was making 108kw at the wheels
Gearbox:
T-50 with JDM bell-housing, full new clutch hard-line
New fluid reservoir (2009)
excedy sports clutch (October 2011)
TRD short shifter
new fluid when bell housing was changed (October 2011)
shifts well
Diff:
S-series with new rear wheel brake cylinders
Suspension:
Front:- ADM struts with coil-over sleeve kit, 8kg springs, tein camber tops, TRD blue inserts non adjustable but very stiff, xt130 lower control arms, 30mm rca's
Rear:- Koni adjustable shocks, 4.5kg ajps springs its quite stiff as there is no weight in the back.
Brakes:
New brake slave, reservoir thing in the engine bay (cant think of actual name but the fluid goes in it)
Front are standard ADM brakes with some good pads
Rear are also standard and hand brake works well
Body:
next to no rust at all just a little in the hatch like every other one. When preparing for paint found some at the top of the passenger B pillar but removed with wire brush and rust kill and filled with booooogggg ha ha and that's it.
dents there are a few little ones from ova the years but you get that.
Paint is 2 pac solid toxic green has the orange peel affect as i forgot to use wax and grease remove before applying paint (kick myself in the nuts)
Origin body kit have spare side skirts and a few other original bumpers
Glass in the rear and passenger door has been replaced with Perspex 6mm
Interior:
all sound deadening has been removed and painted white this includes roof and all pillars
no heater unit but all wiring is still there just tucked up look in the pics
half cage is cusco bolt in type
dished steering wheel and cd player, boost gauge, fixed back drivers seat cheap no namer.
price $7500
location ACT
contact via pm
text only with name to 0468966477
pictures are on car sales as my computer is shit but if you text i can send pics to you.
Postage of vehicle is about $600 to QLD
1247 1252 1282 4294962861 4294964187 1216&silo=Stock&Range=Price:Min,Max~0.5&sort=defau lt
Last edited by BLIPAE86; 7th April 2012 at 11:02 AM. Reason: Update details about vehicle
bump
what type of power is this making more details would help bud
Updated with details
Is the car registered?
yes it has QLD rego until the 19th of april
Pity its not NSW rego or i would be interested, been looking for a project Sprinter for quite a while.
Any offers as im getting married and need some cash
No Reply to my PM's?
You selling stuff Dan?
Im interested, were talking price.
