Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Clutch fan VS non Clutch fan 4age water pumps
  1. #11
    Veteran Nikkojoe's Avatar
    Tom
    4ac is V belt, so different
  2. #12
    Apr 2010
    Mike
    i good condition clutch fan will not suck that much power, and it will move more air then a thermo will
  3. #13
    Aug 2010
    Geoff
    mt dandenong
    true, and a stock cooling setup in good working condition will run cool when driving and thermo will only kick in when sitting stationary for a while. either way is good.
  4. #14
    Apr 2010
    Mike
    16v's you run a switch in the back of the head that replaces cold start injector(wow it turns over 2-3 times more when cold then normal) and it trips at 90 degree's and cuts out at 85 or something i think mine is, tidy as setup
    you have to take into consideration an altinator does need Power for it to work, when you thermo's kick in, drawing 30 odd amps its goign to load the alt more, which will load the engine up more
  5. #15
    Veteran slide86's Avatar
    Huw
    Hills
    so whats the difference between the fan loading up the engine (and doing a better job at moving air than the thermo)
    and
    the alternator loading up the engine to power the thermo fan.....which requires more effort to install
  6. #16
    Apr 2010
    Mike
    my point exactly, people say they drain power, EXACTLY like your alt will powering thermo's
    if you have a good working clutch fan USE IT, if you think its rooted, unbolt the fan(plastic peice) and take the centre to a good parts store they can match them up, or you can buy a repair kit, you drill the centre assembly empty any oil/liquid inside, and refill it with liquid supplied in the kit, then you go over the whole with "knead it" like material, that is supplied in the kit
  7. #17
    Jay
    thanks guys, I need to source a JDM rwd water pump pulley now as I will want to stick with clutch fan setup for better cooling as I dont want to pop my head again, if anyone has a spare pulley let me know.
    Rust is a way of life
  8. #18
    Apr 2010
    Mike
    Contact sc parts, think thats the name, forum sponcer irish bloke
  1. Alternative 4age Clutch Fan Center.
    By pauliee in forum Technical - Questions
    Last Post: 31st January 2013, 01:29 AM
  2. WTB: 4age clutch Fan ASAP!
    By Low Style in forum Cars or Parts Wanted
    Last Post: 13th April 2012, 04:05 PM
  3. WTB 4age RWD clutch fan setup
    By hachirusto in forum Cars or Parts Wanted
    Last Post: 5th February 2012, 04:58 PM
  4. 4ac 4age clutch fan
    By blue86 in forum Car Parts For Sale
    Last Post: 14th September 2010, 10:04 PM
  5. 4age 16v fan fan clutch
    By hutto_t in forum Cars or Parts Wanted
    Last Post: 31st March 2010, 03:28 PM
