Results 1 to 4 of 4
Thread: Indicator problem
    Dec 2011
    beau
    nsw
    western sydney
    Default Indicator problem
    I have a ae71 and during the day my left and right indicators work fine, when I Have my lights on my left indicator stays lit, and doesn't making the clicking noise like it should. Has any body got an idea what it could be or has experienced the same thing?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    flasher can/relay, try another one of them
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I would say the indicator/headlight stalk switch cluster. Common problem on KE70/AE71. I know of 3 cases of this (2 were mine) Just replace the unit.
    It's a cheap fix. bout $20 and half an hours work.
    Veteran stahlz_ae86's Avatar
    Paul
    It will most likely be a break in the wires close to the base of the indicator stalk, ideally you should replace the wires so the problem doesn't re-occur with another second hand unit ready to unleash the same gremlin. Problem I had was the headlights dipping when engaging the indicators, but most likely the same wires that run through the stalk.
  1. indicator/flasher unit problem
    By tezza88 in forum Technical - Questions
    Last Post: 16th December 2011, 12:28 PM
  2. SWAP RHF adm indicator for LHF adm indicator
    By Dori_Dori in forum Cars or Parts Wanted
    Last Post: 16th June 2010, 12:15 AM
  3. Common Problem AE71/KE70 Headlight/indicator Switch
    By stahlz_ae86 in forum Technical - Articles
    Last Post: 24th December 2008, 06:05 PM
  4. ADM INDICATOR
    By Rich_86 in forum Cars or Parts Wanted
    Last Post: 26th February 2007, 12:52 PM
