Results 1 to 9 of 9
Thread: 4agze pistons
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Default 4agze pistons
    Hi there can anyone verify for me that the ae101 gtz rods are any different to a 20v rod? Also the ae92 4agze rod is supposed to be abit beefier which includes the smallport and bigport and stronger is that correct? Theres a set im looking to buy on trademe at the moment and ive given him measurements of the rods but he doesnt seem to think the measurments on this link are the same as his. They are ae101 gtz rods that are for sale. Heres the link for the piston sizes
    The main measurements you should be concerned with is either it takes an 18mm gudgeon pin or a 20mm pin....
    The early model gze rods are thicker than the late model, but given toyota over engineers things i'm sure either should be fine for reasonable amounts of boost.
    Veteran Nikkojoe's Avatar
    Tom
    Epc says that all ae101 4a's ran the same rods. All 7rib 4a's from 88 to 91 ran the same rods( there may be some special cases) which means ae101 and ae92 are different. I remember seeing ae101 vs ae92 rods and ae92 looked thicker
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Ok yea they are 20mm gudgeon pin, They are from a ae101 gtz. I also have a ae92 bigport ze that is turbo in my ae85. But im building a smallport ze for it would it be too much hassle to buy the ae101 pistons and rods then swapping the rods from my motor to the smallport? Maybe just get some aftermarket rods? Or just run with the ae101 ze rods im wanting to run 18psi
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Yea thats correct and yep ae92 are bigger 5mm, is that gonna make a big difference? Anyone else running ae101 ze turbo?
    Not me personally but i know of ppl running around 18psi on the 101 small port rods...
    What turbo / boost are you planning on running?
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    [Ok swt thats reasuring then, Im running a td05h evo 3 core and exhaust wheel/shaft with a 20g compressor wheel and tdo6 comp cover, Is good for 22psi. Will run it at 18psi
    Get the tune right on the dyno and you wont have any problems.
    Jan 2012
    Nathan
    Christchurch
    North New Brighton
    New Zealand
    Ok sweet thanks for you input
  1. 4agze pistons
    By spooldog in forum Technical - Questions
    Last Post: 5th July 2011, 09:42 AM
  2. wtd - 4agze pistons
    By ae71turbo in forum Cars or Parts Wanted
    Last Post: 17th April 2010, 08:27 PM
  3. 4agze pistons
    By greenmac80 in forum Cars or Parts Wanted
    Last Post: 14th July 2009, 01:19 PM
  4. 4AGZE Pistons
    By Gazza_ae71 in forum Cars or Parts Wanted
    Last Post: 3rd September 2007, 12:01 AM
  5. 4AGZE pistons
    By streets in forum Technical - Questions
    Last Post: 1st August 2006, 07:38 PM
