There is no resistor when using a 4age ecu and loom. 4ac (carby) used a resistor and coil. The coils are not backwards compatible, and you must use an ignitor if it says "use with igniter" and visa versa.
*I am assuming what you call "resistor block" is actually the igniter.
Also if that is the case, you need the igniter still.
