Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 35
Thread: Rust Removal Tips n Tricks
  1. #11
    Member Dskew3's Avatar
    Feb 2013
    dustin
    Palmwoods
    this thread is gonna help so much, rust removal is going to be my next mission after i get the car all wired up, i have a bit of rust on my 86 all the suspect spots of course. thanks to who ever started this thread.
  2. #12
    Mt Macedon
    I agree with the above advice. Take out more than you think, because there is almost always more rust on the back of the bodywork that you can't see. If you take out too little then you'll be trying to weld a new piece onto a thin, half rusted body panel. And rust is a nightmare to try and weld to/near. And even if that works there's still a big rust patch lurking on the inside.
    Also take your time and do it properly. I've done a few things quick and dodgy and it comes back to bite you on the arse far sooner than you expect. In my experience it take ages to get a replacement sheet bent correctly and trimmed to fit perfectly, but once welded in you never need to think about it again.
    I must admit I always have to put a bit of bog over the top to get things nice and smooth again and here it's a balance between:
    a) putting so much on that you're sanding all day to get it back to the right level.
    b) putting on too little so there are still some spots that are below the level you want. If this is the case just bite the bullet and bog a little more.
  3. #13
    No matter how much time you spend with a body file, spoons etc you will nearly always need a skim of bog over it
  4. #14
    Senior Member K1W1 Simo's Avatar
    Dec 2012
    Simon
    Mt Coolum
    Does anyone know if replacement panels exist for the " usual" rusted out sections on the 86? Most of the collectable cars around the world have replaceable panel sections for the prone rusty areas of their makes. Usually the panels are made from ex panel presses from the manufacturer, makes life real easy. Rare spares for instance.
  5. #15
    Veteran McLEVIN's Avatar
    Nov 2010
    Impulse in japan do thr rear panel on a 3dr. I think they are gonna do others too
    New panels pop up on yahoo.jp quite frequently
    MOPAR or no car!
  6. #16
    Dec 2012
    Simon
    Mt Coolum
    Making a jig up to replicate the main rusty areas of the 86 wouldn't be difficult. Kick panel in front of A pillar, lower A pillar, sill, lower B pillar. The Alfa replacement panels have really bad fitment- normal for aftermarket parts. These are the parts we need to keep our Toyotas alive. Finding the original presses would be a bonus.
  7. #17
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Like McLiven said impluse in Japan and also
  8. #18
    Numerous people have tried to get hold of the wolf replacement panels previously and had no luck whatsoever I remember stumbling across numerous threads ranting and raving
  9. #19
    Mar 2013
    Mirko
    Dont know much about them just saw it on the net
  10. #20
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    Just stumbled upon this thread, Mirko your panel beater guy it appears he is laying a panel over the top of another panel ? does he cut out much of the rusted panel behind the panel he fits & what does he end up doing with the lip he makes from laying one panel on top of another i'm assuming just bog / blend it, idealy its best to butt weld it in, ie have the repair section exactly the same size as the cut out section & fit it flush & then weld it in takes more time but way better job / finish .. what does he use for welding mig or oxy & steel filler or braizing or tig .. Have you got any pics of a finished off panel ??
  1. Paint Preperation Tips n Tricks
    By Matt in forum Restoration / Body Work
    Last Post: 6th June 2013, 07:40 AM
  2. How to weld tips n Tricks
    Last Post: 21st May 2013, 12:46 AM
  3. Brake Installs – Tips, tricks and products
    Last Post: 16th November 2012, 03:54 PM
  4. Broken wheel nut (Need tips on removal)
    By GOT-20V in forum Technical - Rims & Tyres
    Last Post: 15th October 2011, 02:13 AM
  5. Rust removal
    By lawrencelalot in forum Adelaide & SA Events and Discussion
    Last Post: 16th July 2010, 09:01 PM
