Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 61 to 70 of 112
Thread: Coolant - Engine wont warm up - stays cold
  1. #61
    Gunner
    lol
  2. #62
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    yeah, same Sam.
    Canberra is about 15 today....
  3. #63
    Alex
    Wagga Wagga
    Better bust out the shorts
    Alex's 4AGTE KE70
    Or so was thought...
  4. #64
    JoJo
    ACT
    Tuggeranong
    made little differance Sam92.
    you?
  5. #65
    Gone
    Joel
    Picton
    When you bleed the water system make sure you have the heater on.
  6. #66
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    It seemed to have made all the difference for me. The real proof will be taking it for a drive in the morning and seeing how long it takes to reach operations temp from a cold start.
  7. #67
    Jul 2012
    Wagga Wagga
    Yeah Joel heater tape was open!
    I just cant believe when bleeding it how long it took the thermostat to open and when it did the air came with it. Surely now in the morning the car will heat up quicker.
  8. #68
    Gone
    Joel
    Picton
    Air is a piss poor conductor of heat so makes sense if a decent air/vapor lock is happening
  9. #69
    JoJo
    ACT
    Tuggeranong
    My method today Joel.
    Rear wheels of car on road side of gutter, front wheels on driveway, with the front jacked up, so radiator cap is definatly highest point.
    Cap off,
    Heater on full blast,
    Run engine untill bubbles stop and water starts flowing. (20 mins+) Monitoring temps, both at the thermostat housing and the top hose. While warming up, I squeeze the heater hoses etc, to help move any air.
    The only change today was that I now have the heater working in the car. Blows hot air now, and cooler air on cold. I did change the heater tap as well as the bleed.
  10. #70
    Jul 2012
    Wagga Wagga
    My exact method, I elevated the front of my car also and helped by squeezing the hoses with the heater going flat out.
    So you have no improvement on operating temp ? Only the heater has improved ?
  1. 16 4age wont warm up
    By Rice86 in forum Technical - Questions
    Last Post: 24th January 2012, 07:24 AM
  2. 4age engine temp and warm up time.
    By odessy in forum Technical - Questions
    Last Post: 29th October 2011, 04:53 PM
  3. Replies: 4
    Last Post: 30th October 2010, 02:04 AM
  4. cold engine problems
    By Johnny_08 in forum Technical - Questions
    Last Post: 4th December 2007, 10:11 PM
  5. sound from engine when it is cold?
    By Ksevn-T in forum Technical - Questions
    Last Post: 12th May 2006, 08:35 PM
