Results 1 to 7 of 7
Thread: Bigport 4age Throttle Body Vacuum etc
    May 2013
    South Australia
    Default Bigport 4age Throttle Body Vacuum etc
    hey guys...
    can someone tell what the part circled in green is...and if i can get it new...current manifold doesnt have it
    also...where do i get the plugs to cover the other vac lines?
    cheers all!
    Aug 2010
    Geoff
    mt dandenong
    Self serve wreckers are good for those bits. Its a throttle stop dampener if im correct. Have gotten away without using it before but worthwhile to have. Might have a spare one around if you can't find one.
    there's more details as to why it's good to have when adjusting your idle/throttle stop but im probably not the best at explaining it
    Senior Member shammy's Avatar
    shamus
    vic
    albury/wodonga
    aus
    yer pretty much what grey said, it advances your timing as the revs increase, + throttle body cooling to help with combustion, contains a wax pellet that has issues with age, best bet would be to fabricate a block off plate and remove it, its not a big job or you can folk out and pay a stupid amount for one
    Veteran Nikkojoe's Avatar
    Tom
    I think Chris is just talking about the lines on the cold start idle up unit, not the unit itself. As Geoff said, it's not really needed but does stop the throttle returning sharply.
    Also make sure you block off each port separately and not loop two of them together with a hose
    May 2013
    South Australia
    thanks guys...a trip to the wrecking yard it is!
    if i dont find one, ill hit you up geoff!
    Aug 2010
    Geoff
    mt dandenong
    No probs. In a nutshell when you release the throttle it acts like a cushion so the rapid closing of the throttle doesn't make your car stall. Air travels through it so if you find you have wound your idle screw all the way and the car still idles high you need to adjust this thing.
    I've been mucking around with this stuff for ages trying to get a decent idle. For me at least its been a nightmare.
    And dont ditch cold start unless you have to. Its good to have.
    Last edited by dove grey 64; 8th August 2013 at 09:20 PM. Reason: fixing auto spell
    Veteran timbo's Avatar
    Tim?
    Wild West
    I had to pull mine off as it was shagged and idled the car around 2000rpm! Fine without it but cold starts are a pain plus no "cushioning" which is nice.
  1. WTB 4AGE Bigport throttle body. Gold Coast
    By mrmatt in forum Cars or Parts Wanted
    Last Post: 6th June 2012, 10:59 PM
  2. WTB: 4AGE Bigport Throttle body with TPS (Pref)
    By Kwan in forum Cars or Parts Wanted
    Last Post: 4th April 2011, 01:05 AM
  3. 4age throttle body RWD bigport
    By TurboRA28 in forum Cars or Parts Wanted
    Last Post: 3rd September 2010, 08:02 PM
  4. (SYD) bigport intake with TVIS and throttle body $220
    By Leigh in forum Car Parts For Sale
    Last Post: 5th July 2010, 12:26 PM
  5. 2x big port inlet manifolds. 1x bigport throttle body
    By LordNafe in forum Car Parts For Sale
    Last Post: 1st June 2010, 08:57 PM
