Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Rear Main Seal - cause of failure shortly after install?
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default Rear Main Seal - cause of failure shortly after install?
    Ok long story short, rebuilt 4age 16v in my gti ae92, just got it in and running over the weekend, after a quick lap of my street I discovered a chronic oil leak between bellhousing/block... rad not...
    Anyhow pulled gearbox off this morning and found my rear main seal (which was brand new genuine) to be almost all the way out of the housing... rad not...
    It was installed properly/straight, my exact procedure was that I put the seal face down on a flat surface and pressed the housing over it so the face of each was flush and level, a little bearing lube was used to aid the install....
    Wtf happened to make it fail like it did? does the seal need to be pushed deeper into the housing past the face? that's the only thing I can see be a factor, not much else can change really.. Ive done a few rear mains and never had a drama before?
    Cheers for any insight
    Niz
    BENT MECHANIX - Garage 20:
    Gunner
    bearing lube
    it should a couple mm in from the face. if it was flush it wasn't in all the way. so that plus the bearing lube, and it would of pushed itself out the first time it got full oil pressure
    Niz
    South~Slide Briz
    So don't lube the outside face of the seal at all when installing?
    I normally push them in with a 1/4" extension bar.. start at 12 o'clock, then 6, then 3, then 9 and work my way around until it is in.
    The clutch plate will also be soaked in oil, and may cause issues with the pads.
    Gunner
    only lube the inner of the seal, where the crank turns.
    Niz
    South~Slide Briz
    sweet, cheers gunner, all I needed to know.... Matt, clutch is sweet, no oil to be seen on it nor the flywheel surprisingly so all good there... I prefer to push them in with equal pressure on the complete surface
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    What Gunner said...... I only lube the inner seal edge on those type of oil seal rings
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    Have you taken the box off to see what went wrong as in is the seal still in place ?? as has been said ideally no lube should be used on the outside & also I keep an eye on how easy the seal goes in & if it goes in very easy I put a smear of silicone on the very outside face outer edge to housing rim, just a bit of piece of mind ... As has been said you must put a smear of grease on the complete seal lip & even a light bit on the crank too ..
    Senior Member Willofan's Avatar
    Jan 2011
    Caringbah
    I am surprized no one has mentioned excessive oil pressure from a stuck/seized relief valve in the oil pump. The rear main is the weakest link above 80psi
    Did you notice anything on the guage when you went for your run around the block??
    Niz
    South~Slide Briz
    on that note could it be anything to do with the pressure relief valve in the factory oil filter sandwich plate? as it was removed and re fitted, done right as far as I'm aware though, all by the manual,
  1. rear main seal
    By sic86 in forum Cars or Parts Wanted
    Last Post: 13th October 2009, 01:17 AM
  2. how to take out rear main oil seal retainer
    By driftster in forum Technical - Questions
    Last Post: 2nd July 2007, 02:48 AM
  3. 4age rear main oil seal
    Last Post: 27th June 2007, 02:34 PM
  4. ae101 rear main seal
    By Blown86 in forum Technical - Questions
    Last Post: 29th August 2005, 08:53 PM
