Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: car shakes on idle.
    Ade
    SYD, Inner west
    Default car sounds like a diesel truck!
    hi
    Car is making some hectic noise. rattling and what not!
    sounds like a bunch of monkeys are having a fight in my motor with pots and pans!
    just changed leads, points, cap, sparks.
    could be the timing, as it sounds like a diesel!!!
    just thought i'd ask.
    any pointers would be appreciated.
    just added a video, AND THE SOUND IS NOW WORKING. (last one had no sound) check it out and let me know what you think?
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hdEjnukRZl4&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/hdEjnukRZl4&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    Last edited by Ade_Mc; 12th July 2009 at 08:32 PM. Reason: added video, now with sound!
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    dropped a cylinder ade?
    Veteran Nikkojoe's Avatar
    Tom
    Carby working fine? Its probably needing a good clean out with carby cleaner and also installing a small rebuild kit (new needle, plunger, gaskets etc).
    Mt Macedon
    I'm assuming 4AC here, but I had a similar problem once, shuddered at idle, but was ok once going. Rallystanza diagnosed it as a vacuum hose fallen off under the airfilter. There are 11000 of them, but it may be worth a look.
    Ade
    SYD, Inner west
    cheers, i will check it out.
    i would buy a rebuild kit but i have a twin webber sitting around, will be putting that on soon.
    i hope it hasn't dropped a cylinder. been driving it for over two weeks now.
    once its going its kind of ok.
    will check the vac hoses.
    Kieran
    inlet manifold gasket leaking? that could cause the car to run unevenly...
    Ade
    SYD, Inner west
    that could be possible, since dumping the ride height, i have had a could big scrapes. but don't think it would of broken off. More likely it would of broken off at the hot dog or on the muffler somewhere.
    checked the vac hoses, them seem all good.
    the search continues
    Dim
    Menai
    I've got this issue too. Not too violent but this advice is very helpful.
    Concidering you just changed a whole bunch of parts, the question is, was it doing this BEFORE you changed the parts? If it was'nt, then I would say you've installed something wrong, or something is faulty and hence, your engine is'nt firing on one of its cylinders.
    Senior Member racsov's Avatar
    Nick
    West
    yeah sounds like engine mounts or exhaust rubbing
  1. Please someone help!!! (idle)
    By A.k. in forum Technical - Questions
    Last Post: 18th November 2010, 12:47 PM
  2. idle up and down
    By wntdae86 in forum Technical - Questions
    Last Post: 5th October 2010, 11:43 AM
  3. adjusting idle
    By VTAZ! in forum Technical - Questions
    Last Post: 10th January 2010, 03:41 AM
  4. Low Idle...What could it be?
    By PeakingDuck in forum Technical - Questions
    Last Post: 10th May 2009, 03:20 PM
  5. Lumpy Idle.
    By 20sil in forum Technical - Questions
    Last Post: 26th February 2007, 08:59 PM
