Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: car wont start after cams, port/polish
  1. #11
    E-Famous (Remeber your roots)
    I would make sure the gears are set correctly for the cams. Check the timing belt is setup correctly.
    Check injector pulse.
    Hasn't lost a tune?
  2. #12
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    As has been said double check the cam timing & also Have you checked the valve clearances with the New cams installed as the clearances could be really tight now ??
  3. #13
    Veteran Nikkojoe's Avatar
    Tom
    Most important thing is make sure the cams (not cam gears) are lined up. Locator pin on intake cam should be at 12o'clock, locator pin on exhaust cam should be at 4 o'clock.
  4. #14
    Jun 2011
    james
    oxford
    general area
    England
    If you are using the distributor is that timed right ?
    I find the best way to check it is to turn over the engine by hand until it is at compression TDC on No1. cylinder, remove dizzy cap and rotor arm and then look very closely at the rotor with the four teeth, one of the four teeth should be inline with the thin metal bar on the sensor inside the dizzy. If it is not inline just turn the dizzy until it is.
    To ensure it is firing on the correct cylinder re-fit the rotor arm and make sure it is pointing to No.1 spark lead on the dizzy cap.
    Timing the distributor as above will get it close enough to run.
  1. Car wont start
    By MeZ Prod in forum Technical - Questions
    Last Post: 15th February 2012, 11:50 AM
  2. car wont start.... help!
    By 20v ae71 in forum Technical - Questions
    Last Post: 17th March 2011, 08:40 PM
  3. Car wont start
    By Ko Ko in forum Technical - Questions
    Last Post: 18th April 2008, 08:36 PM
  4. Car wont start
    By Granto in forum Technical - Questions
    Last Post: 29th April 2007, 06:44 PM
  5. Car wont start
    By in forum General Topics (No Technical Questions)
    Last Post: 1st January 1970, 11:00 AM
