Results 11 to 20 of 23
Thread: Building my own dash cluster and looking for advice and tips from ppl who have done it
  1. #11
    Veteran McLEVIN's Avatar
    Nov 2010
    thats what the one i posted is. here is a kit for s2000 dash
    MOPAR or no car!
  2. #12
    Yep has to be wired from scratch, electronic speedo sender was used too on that dash.
    is where the build thread is located, a 2zzgte into an ae82 sedan.
  3. #13
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    No luck at all finding it matt
  4. #14
    Mar 2013
    Mirko
    scap that had to create account to find it thanks again matt
  5. #15
    Jason
    Southside
    pic of the finished cluster I built:
    It's a 3mm steel plate I had laser cut, welded posts to the rear to mount it to the back white plastic housing of an original cluster, made housings and LED holders for the warning/turn lights etc. All speedhut gauges from the US
  6. #16
    Veteran drift kid's Avatar
    Glossodia
    Fark, why 3mm? Looks sick man but a little overkill
  7. #17
    Mar 2013
    Mirko
    That's off tap can u post pic of back as well. what did laser cut cost u
  8. #18
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    I am looking at doing something very similar with speedhut gauges at the moment. For those of you that haven't had a look at them they will basically make whatever gauge face you want... as in whatever you want...
    I am planning on making my gauges look as similar as possible to my Pivot tacho
    How do you find the actual quality and accuracy of the gauges Jason?
    Current Cars:
  9. #19
    Jason
    Southside
    it's 3mm as the plate has recesses milled 2mm into it to accept the warning light acrylics for the turn signals/warning lights. Was somewhere between $15 and 30 to get cut, I can't remember as I had it done with a batch of 2J and 2zz flanges.
    Back shot of the plate with additional housings and mounting posts:
    Gutted plastic housing with plate bolted in:
    And a shit photo trying to show the lighting:
    The gauges are great quality IMO, would be better if they used smaller gauge wiring though as when you have so many together the loom gets a bit bulky.
  10. #20
    Glossodia
    Oh fair enough man, looks great
  1. Replies: 1
    Last Post: 29th June 2011, 04:24 PM
  2. can anyone help me take out my dash cluster
    By bones in forum Technical - Questions
    Last Post: 25th June 2010, 04:32 PM
  3. Installing a W58 into my AE86 - Any advice/info/tips???
    By Maxhag in forum Technical - Questions
    Last Post: 9th April 2008, 10:51 PM
  4. AE86 dash cluster
    By Clinton -KETO- in forum Technical - Questions
    Last Post: 16th December 2007, 08:14 PM
  5. AE92 S/C dash cluster
    By GZE KE70 in forum Car Parts For Sale
    Last Post: 16th February 2007, 04:07 PM
