Results 1 to 10 of 13
Thread: High Comp 20v BT Injector Upgrade.
    Senior Member Zane k's Avatar
    Aug 2011
    Zane
    Gold Coast
    Default High Comp 20v BT Injector Upgrade.
    Okay so I can't seem to find any specific information on this, I'm currently building up a High comp N/a 20v BT and I'm just considering upgrading the injectors, I'm going to be running either a Haltech Sprint 500 or Haltech Sport 1000, Im just curious what people here have gone with or if you could give me any advise/ options on some good injectors I could upgrade to, This is my build. Thanks in advance.
    CP 81.50mm bore high compression forged pistions C/R 12:5:1
    Brian Crower H beam forged condrods
    ARP head studs
    Kelford 194-C racing cams
    Intake: 284' Duration 9.30mm Lift.
    Exhaust: 278' Duration. 8.50mm Lift
    Kelford Cams racing vavle springs
    Full head reco port and polish
    TRD 0.8mm multi layer metal head gasket
    HKS timing belt
    1zze Coilpacks
    TailorMade☆DC
    20v 4AG Corolla:
    Moderator Frak's Avatar
    Jamie
    Depending on how much fuel you need, Japanese 2JZGTE will fit straight in and give you 440cc, USDM 2JZGTE will give you 550cc, this is what I used in my BT.
    Hachiroku since 1994
    Sep 2012
    Tristan
    Koongal
    i got advised that when i build my N/A 20v ST i would need around 500cc, he said as a guesstimate you double the CC to how much HP you want to make. i would love to know when i could find some injectors though so let me know if you find any
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I have a set of 6 2JZGTE 440's if you want them. $150
    Mt Macedon
    Twisty, those number you give seem too high. There are a few injector calculators around the net that can give you an idea. And form my experience on a 4AGZE I've made 110rwkw on 365cc injectors and 140rwkw (optimistic I feel) on 440s without problem.
    Aug 2011
    Zane
    Gold Coast
    I've been told that in my case there is no need to upgrade from the standard injectors as they have seen the standard ones on a 250hp+ 20v running it fine?
    TailorMade☆DC
    20v 4AG Corolla:
    Aug 2011
    Zane
    Gold Coast
    Thanks man but if I do upgrade I'll be buying new.
    TailorMade☆DC
    20v 4AG Corolla:
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    I'm running very close to the same setup as you're describing here. Same pistons, cams and springs you've suggested. Only difference being I've got Spool rods and using a standard thickness head gasket.
    I've had no dramas throughout tuning and to this point running the standard blacktop injectors.
    Aug 2011
    Zane
    Gold Coast
    Can I ask what engine management system you're running and also what power output? Would be highly appreciated.
    TailorMade☆DC
    20v 4AG Corolla:
    Jun 2011
    Daniel
    Townsville
    I'm using an Adaptronic E420C, still retaining VVT. My engine makes 143hp at 8500. Still very streetable, and makes a comfortable amount of torque for getting around town at low revs.
  1. Injector upgrade - ST20V
    By Futo_gt86 in forum Technical - Questions
    Last Post: 26th April 2012, 06:53 PM
  2. Injector upgrade options
    By ae86 slide in forum Technical - Questions
    Last Post: 20th November 2010, 10:52 AM
  3. comp test on bt 20v
    By slider4life in forum Technical - Questions
    Last Post: 21st July 2010, 07:09 PM
  4. High revving BT 20v???
    By slideways in forum Technical - Questions
    Last Post: 13th April 2010, 10:08 PM
  5. high comp headgasket on gze
    By dustyae86 in forum Technical - Questions
    Last Post: 17th July 2007, 02:33 PM
