Results 1 to 10 of 12
Thread: 4AGE Bigport 90% complete
    Veteran Nikkojoe's Avatar
    Tom
    Default 4AGE Bigport engine with loom and ecu 90% complete
    Removing my 4age bigport (bluetop) out of my white ae86 as its getting replaced with a fresh rebuilt engine.
    Engine was originally bought from KYP 10months ago. All the seals have been changed from top to bottom bar the valve stem seals, and the timing belt is new. Engine has done 3000km since being installed and starts first time every time. Compression tested a few months ago and got 180, 170, 170, 175 which is healthy for a bigport (uses no oil).
    The engine is pretty much complete minus the intake and exhaust manifolds (engine is priced accordingly - can be easily found on forums), no mounts or flywheel/clutch, rwd dizzy needs cap and rotor. Comes with fwd water setup, alternator and crank pulley and can be converted to rwd easily if wanted. It will also come with a loom and ecu with injectors and sensors to suit, but no coil/igniter.
    Inspections can be made for the next few days only as it will be removed before the end of the week.
    Price: $800ono (can be wired for extra)
    Located Perth NOR.
    PM me for more questions.
    Tom
    Here is a pic of it before installation. Differences are the cam covers will be just silver and missing the rwd gear.
    Tom
    Engine will be removed tomorrow
    Tom
    Engine is out and is almost ready to go. Have the came covers off and going to check the clearances.
    Darren
    Fanatic owner, is a great buy people people, very well presented and built engine. Will not dissapoint
    Tom
    Cheers.
    Can also supply partial rwd water setup at an extra cost (rwd water pump/rear housing, side pipe with cold start lines, rwd rear water plate, rwd top water outlet - no alternator bracket, bypass pipe and thermostat outlet).
    Tom
    Checked the clearances, all good.
    Bump.
    Tom
    anybody interested? offers?
    Tom
    Bump.
    Nobody in Perth wants a good 4age? All you really need is a rwd intake manifold and rwd exhaust manifold and a few minor bits and its ready to go.
    E-Famous (Remeber your roots)
    Post?
  1. WA: ke70 4agze 90% complete
    By Wally332 in forum Cars for Sale (Toyota Only)
    Last Post: 19th September 2012, 04:36 PM
  2. bigport 4age complete motor with loom and ECU
    By leigh4110 in forum Car Parts For Sale
    Last Post: 29th May 2012, 09:53 AM
  3. [melb] 4AGE bigport complete
    By van_ in forum Car Parts For Sale
    Last Post: 22nd January 2012, 09:35 AM
  4. Blacktop 20V Complete - 90,000km
    By tuned86 in forum Car Parts For Sale
    Last Post: 18th November 2009, 09:03 PM
  5. [SYD} Near Complete 4AGE 16V BIGPORT!
    By drif86s in forum Car Parts For Sale
    Last Post: 16th March 2008, 11:08 PM
