Results 11 to 20 of 21
Thread: Idle & Low rpm miss fire - Bigport
Threaded View
    Default Idle & Low rpm miss fire - Bigport
    AE82 Bigport motor only has 20,000 on it since rebuild.
    TVIS is hooked up, RWD manifold from JDM biport, Installed and wired in by me ~2 months ago,
    has developed a idle and low rpm miss fire in the last 2 weeks. Any thing over 4000~4500rpm is
    clean and free revving, anything under 4000 will not hold even rev and misses. I changed plugs,
    leads, dizzy cap and rotor but still does it. I didn't wire up the Diagnosis plug, so don't know if its
    throwing a code
    When driving if it has load on it then its OK, but cruise it will miss. It feels a
    little bit rich, 1st to 2nd, 2nd to 3rd will pop a little back fire between gears driving sedately.
    Timing is set to 0 on the marks, runs on 98 octane only, no pinging and has heaps of power, but yeah...
    I noticed if I pinch the MAP sensor hose the revs clean up and the miss at idle
    goes away, also it will hold clean even rev @ ~2500-3000rpm (can't see tacho).
    I have the MAP and the stock FPR T pieced together off 1 brass fitting in the
    back of the manifold. I was told that full vacuum signal to the FPR will make it
    run choppy at low rpm? Could this be my issue?
    Does anyone in Brisbane have a Bigport MAP sensor I could borrow and see if
    this is my problem?
  1. Surge @ Low RPM.
    By 4agejet in forum Technical - Questions
    Last Post: 4th March 2011, 10:06 AM
  2. 4age splatter at low rpm
    By ae13b in forum Technical - Questions
    Last Post: 10th February 2011, 11:23 PM
  3. 4k miss fire/over fule
    By stx-16 in forum Technical - Questions
    Last Post: 17th July 2009, 01:00 PM
  4. 4AC miss fire???
    By Ade_Mc in forum Technical - Questions
    Last Post: 24th January 2009, 05:35 PM
  5. random change in idle rpm
    By 4agze-hachisaurus in forum Technical - Questions
    Last Post: 21st April 2006, 06:02 PM
