Through process of elimination I disconnected the TVIS which has helped
with cruise.
I disconnected the sensor next to the cold start injector, biggish yellow plug,
this also has helped some.
Right now, its running better than it was, idle(~900) -2000rpm is smooth,
if I try hold a rev over 2000-4000 it will miss, its only a tiny miss, but its shitting me to death.
I'm getting a compression test done tomorrow and might clean the injectors also.
Are 4afe grey top injectors the same as the 4age bigport grey tops?
