Results 211 to 220 of 1384
Thread: Touge's Levin coupe - "Why come to adelaide? Because we have pandas...."
Threaded View
    Veteran Touge Boy's Avatar
    Modbury
    Default Touge's Levin coupe - "Why come to adelaide? Because we have pandas...."
    1984 Zenki AE86 Coupe.
    Bought it, broke it, rebuilt it, drifted it, smashed some stuff, tore it down, and now Im rebuilding it again.
    Decided to go all out, and build the best 86 I could. ive spent way too much money on it, and havnt driven it as much as I probably should of, but it'll be worth it in the end.
    Body
    Vertex Copy aero, Levin window visors, Kouki headlights and parker lights
    20% window tint, 800K HID kit, Painless Wiring wiring loom, Switchpanel and fusebox
    Re-sprayed in Hilux white/Gloss Black bars
    Interior
    Buddyparts Cams-Approved 6 point bolt-in cage with side-intrusion and harness bars
    Dash and door trims re-trimmed in black suede, Alloy foot plates
    Velo GP90 +1 seats in red on modified velo rails rails, Velo 3 inch 5-point harness x 2
    Momo Mod08 steering wheel in black suede, Detachable hub kit, Autosport Hydraulic Handbrake
    Autometer tacho, water temp/oil temp/oil pressure/fuel level/Fuel Pressure gauges, APEXi RSM
    Engine / driveline
    SXE10 3SGE Beams motor, Buddyparts engine/gearbox mounts and transmission tunnel
    AE111 20V quad-throttles, T3 velocity stacks, TRD Quad throttle adapter, custom throttle linkages
    HKS Stainless Headers, Buddyparts 2.5 inch exhaust
    Adaptronic E420C ECU Tuned by Nick @ Buddyparts - 140rwkw
    RCi 15 Gal. Alloy Fuel Cell , 2.5ltr. surge tank, Carter lift pump, Bosch 044 fuel pump, SARD FPR
    J160S 6 speed gearbox, Exedy "Hyper-Metal" Super-single plate clutch with lightened flywheel
    Custom 3 inch single piece tailshaft with H/D uni's
    T-Series disc rear end, TRD 2way L.S.D, TRD 4.11 gearset
    AE101 Alloy radiator with 2 x 12 inch thermofans
    Custom 25 row Earls oil cooler kit with filter relocation
    2ltr Pederson Fabrication catch can with breather
    Optima dry-cell battery relocated to rear with remote battery kill
    All speedflow lines and fittings throughout
    Wheel and Tyres
    RS Watanabe R-Type wheels in silver/machined lip, 15 x 8.5 -6 and 15 X 9.5 -19
    195/50 R15 Toyo R1R front tyres, 195/50 R15 China junk rear tyres
    Suspension setup - FRONT
    BC Coilovers, Adj. cambertops, 8kg springs, Buddyparts 40MM RCA
    T3/Wilwood big brake kit, Goodridge Braided Brake lines, Hawk HP Plus pads, Cusco BCS, Wilwood Bias Adjuster
    Rebuilt steering rack with lock spacer, URAS Super tie rods, T3 adj. tie rod tubes and Rose-jointed TRE's
    T3 super-lock knuckles
    Rose-Jointed Adj. Castor arms
    Whiteline 24mm swaybar
    Cusco OS Tower Bar
    Suspension setup - REAR
    BC Height/damper adj. struts, BC Adj. Spring platforms w/ 6kg springs
    T3 Adj. pillowball 4 link
    Buddyparts Adj. Traction Brackets
    T3 panhard rod
    Whiteline 18mm swaybar
    RDA Slotted rotors, Goodridge Braided Brake lines, Project Mu D1Spec pads
    Coming next
    finishing touches, smashing into more stuff and generally just driving the piss out of it and enjoying myself after a very long and testing 12 months.
    And the final piece of the puzzle.... bought this.
  1. Wanted 13 or 14 Watanabes 6 6.5 or 7 :-)
  2. """"rear springs and dildo shifters""""
  3. FS: KE70 number plates. Adelaide
    By gooza in forum Car Parts For Sale
    Last Post: 26th June 2009, 02:07 PM
  4. My ae85 levin coupe "svetlana"
    By The Enthusiast in forum AE86 Owners Forums
    Last Post: 24th May 2009, 11:15 PM
  5. WTB:jdm levin letter box type grill
    By Jimbo-AE86 in forum Cars or Parts Wanted
    Last Post: 5th February 2007, 10:50 AM
