Results 1 to 9 of 9
Thread: Does BT 20V ECU prime fuel pump?
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    Default Does BT 20V ECU prime fuel pump?
    Hey guys,
    Just wondering if the BT 20V ECU is suppose to prime the fuel pump when ignition is on?
    Gone
    Joel
    Picton
    im just writing becasue no one has, this was brought up somewhere mid topic in here, the 4a ecu doesnt prime the fuel pump, i think HEN the NUT will be able to confirm this or golberg, but i think it only switiches the pump on once u engage the starter.
    Jun 2009
    Grant
    California
    San Jose
    USA
    I know for sure the BT ECU doesn't prime the fuel pump. The pump turns on with the starter switch, and continues running when the ECU knows the engine has caught and is running. The ECU keeps the pump running.
    On a ST, it's the same deal, but the AFM keeps the fuel pump running as air pulls the flapper open. The ECU is not directly connected to the fuel pump in this case.
    Vesley
    Geelong
    Ah sweet, Thanks for that guys. The motor starts and runs fine but I just thought it was a bit weird the fuel pump didn't prime, just a bit of peace of mind to know everything is wired correctly.
    Jason
    Southern Suburbs
    Toyota fuel pumps have non return valve/design. No need to prime.
    Vesley
    Geelong
    Hmmm... I'm using a nissan pintara fuel pump, not sure if it has a non return valve. Do you reckon it'll matter?
    Would it basically mean if I didn't use the car for a couple of days it would take a bit longer to crank the engine over?
    Veteran Nikkojoe's Avatar
    Tom
    Pretty much ^^
    Although I think it will take less than a day for it to happen. As long as it starts reasonably quick I wouldn't worry anyway
    Vesley
    Geelong
    I've left it for a week and haven't noticed any difficulties starting, guess it must have a check valve.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    This is correct, the first thing that triggers the pump is turning to start. The ECU doesn't prime the fuel system.
  1. 20v bt loom and ecu
    By dehney in forum Cars or Parts Wanted
    Last Post: 28th October 2012, 05:56 PM
  2. wtb stock 20v bt ecu
    By MattybT184age in forum Cars or Parts Wanted
    Last Post: 4th September 2012, 12:13 AM
  3. 20V BT fuel pressure
    By Grant #2 in forum Technical - Questions
    Last Post: 22nd October 2009, 06:25 PM
