is the loom and ecu to suit a big port?
out of a ae82?
Item:
1. ae82/92 4AGE crank pulley
3. ae92 4age water pump, rear housing and side pipe
4. ae92 Top water outlet, side pipe, alternator slider and bottom alternator mount.
Pic of bottom mount below
5. AE82/92 4age alternator bracket x2 (no alternator included)
6. 4age 16V timing belts, one with 30,000km life left and another with 60,000+
7. ae92 oil sump with standard oil cooler return and windage tray (needs a clean - PICK UP ONLY).
9. ae92 remote thermostat housing with thermostat- No hoses included
10. 3x ae92 smallport pistons and rods (4th damaged).
11. 1x bigport cam gear (works on either inlet or exhaust)
12. 2x 4agze fuel rails, 1 with n/a fpr and 1 with gze fpr
13. Smallport 4age crank, damaged 4th bigend facing - FREE Pickup only
14. RWD bigport dizzy, no rotor or cap
15. AE82 FWD throttle body
16. AE92 smallport FWD intake manifold
19. AE82 4AGE map sensor
20. 4AGE bigport O2 sensor
22. 4A clutch fans
23. AE82 Redtop 4AGE Loom and ECU with injectors
More items when I find/remember them
Price:
1. $15
3. $20
4. $20
5. $5 each
6. $5 each
7. $20
9. $25
10. $50
11. $5
12. $5 each
13. Free
14. $30
15. $10
16. $5
19. $40
20. $20
22. $10 each
23. $150ono
Pictures will be on a request basis. If I get a chance to take pictures of all items I will but if there is something you want I can quickly take a picture for you.
Location: Located Perth NOR, will post at buyers expense. No offers including postage will be accepted.
Contact: PM or contact me in this thread
out of a ae82?
Yep, its a late model loom which has some plugs slightly changed although I will provide these sensors so its a bolt on affair.
I am interested in item 1 and 12s along with much more.
bump.
bump.
First post updated as 17&18 have been removed.
Updated with some pictures
hey mate wondering if you still have the bigport o2 sensor ? what condition is it in how old is it?
I'll have to let you know what im doing with it as I might end up using it. Its in good condition, off a jdm rwd 4age and in working order. Some of the heat insulation wrapping is a bit freyed at the sensor join but the wire is good.
