Results 1 to 10 of 10
Thread: Aircon compresser removal
    Veteran Robo86's Avatar
    Rob
    Cool Aircon compresser removal
    Car - JDM AE86
    motor - Big port 4age
    use - skids
    problem - Air con Compressor removal
    occurs/started when - engine removal
    personal situation - ffs.
    Hey guys
    Is it safe to just remove the two flexible hoses that go into the compressor, or will we die?
    also, removing the aircon completely is out of the question, and is not up for debate!
    thanks guys
    robo.
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Veteran Nikkojoe's Avatar
    Tom
    You wont (as long as you hold your breath) but the atmosphere will.
    not saying you should do it unless its pretty much out of gas anyway
    Ok
    Seamus
    Milton
    cool, so minimal death and we just need to get the system regassed afterwards?
    Tom
    so why are the lines gettng removed? Removing the engine?
    if so just unbolt the compressor and tie it up to the side
    Darren
    assume ur gettin rid of it. Undo the low pressure side, the side that freezes up when its runnin... it will go off with a bang. an it smells bad an u may turn green
    Site Supporter Javal's Avatar
    Josho
    Go to a mechanic. Get it de-comissioned (degassed). Pay the man not alot of money.
    Remove all components.
    Win.
    I've done it the dodgy way before. Don't.
    Calvin
    Kilsyth
    undo compressor and tie to the side if you wish to keep it. othewise jst open the bleed valve up and vent it at your neighbours or perhaps some small children that might be around
    T18 in the build
    Ok
    Seamus
    Milton
    yep, we'll move it off to the side, that was the original thought
    cheers guys!
    Josho
    Oh, you're changing engines, not removing the aircon?
    In this case, unbolting the compressor and moving it off to the side is the preferred method.
    You win the prize.
    Rob
    prize won!
    my corolla
    3274 5374 - Roy
  1. aircon
    By wntdae86 in forum Technical - Articles
    Last Post: 11th April 2010, 06:43 PM
  2. a/c compresser dilemas
    By @gent86 in forum Technical - Questions
    Last Post: 6th July 2009, 10:34 PM
  3. AE86 aircon, you got it??
    By drift kid in forum General Topics (No Technical Questions)
    Last Post: 6th January 2009, 08:40 PM
  4. e70 aircon
    By 4slidn in forum Car Parts For Sale
    Last Post: 14th June 2008, 01:36 PM
  5. Aircon recharge
    By Sanity Clause in forum Technical - Questions
    Last Post: 15th May 2008, 01:27 AM
