Results 1 to 10 of 13
Thread: 4age 16v sump gasket change
    Senior Member Waddles's Avatar
    Wade
    Default 4age 16v sump gasket change
    hey people,
    my 86 is getting a bit of seepage of oil from my sump gasket, nothing extreme just building up overtime and looking a bit dirty underneath, my car running really good, so just wondering is it easy enough to change the sump gasket?
    and cause i have never bought one are they easy enough to get hold of?
    it looks straight forward but yeah i willing to give it a go to learn to fix these things, my oil due for change very soon, so wanting to do it then.
    if anyone can help i would love the input thanks
    Veteran shift_rook's Avatar
    SE Burbs
    jsut try nippin up the bolts firstly, otherwise it's not that difficult, truthfully never done one on a 4age but a fair few other cars, very straight forward undo bolts, take away, clean up ocntact area and apply, maybe a bit of gasket glue if you wanna get carried away
    Wade
    yeah i will try tightening bolts and then clean underneath. if still happening i get new gasket. thanks mate
    Senior Member Dylan's Avatar
    Dylan
    4A engines don't use a gasket. Just a silicone type sealer between both sides (sump and windage tray). If using a gasket you'll need two as well as longer sump bolts
    Wade
    now i just confused
    Steve
    dont be
    4ac has a listing for a sump gasket but 4ag doesnt.
    sump bolts very short, meaning if you gasket it you will need longer bolts.
    just remove sump, clean contact area then apply any type of quality sealant
    simple really
    Wade
    ok no worries, i get it. well i just learnt something, i didn't know there was no gasket. thanks i will give it a go
    Veteran Nikkojoe's Avatar
    Tom
    Correct, there is no gasket, and even 4ac dont use a gasket.
    Use a grey based RTV silicone. You may want to loosen the engine mounts and lift the engine to gain clearance between the crossmember and sump.
    Senior Member kronix's Avatar
    Wade
    Stafford Heights
    i work at toyota and we use stuff called (FIPG) its black, go to you local dealer and pick some up... its good stuff
    Wade
    Wade
    cheers guys for the info, do i have to lift the engine and loosen engine mounts cause i dont have equipent to do that??
  1. Brand New TRD Head Gasket Brand New 4AGE 16V 0.8mm
    By bernard in forum Car Parts For Sale
    Last Post: 30th May 2013, 09:06 PM
  2. 4AGE 16v OEM Head Gasket
    By anastasios in forum Cars or Parts Wanted
    Last Post: 6th November 2012, 11:54 AM
  3. SA: 4age 16v smallport throttle body gasket
    By keimeier in forum Cars or Parts Wanted
    Last Post: 6th April 2010, 10:41 PM
  4. TRD 0.5mm Metal Head Gasket - 4AGE 16V
    By adam in forum Cars or Parts Wanted
    Last Post: 23rd June 2009, 10:41 PM
  5. TRD 0.5mm Head Gasket 4AGE 16V
    By Jazz9 in forum Car Parts For Sale
    Last Post: 7th November 2007, 02:48 PM
