Results 1 to 4 of 4
Thread: Who has the template for the hydraulic clutch into ke70??
    Member Golden Circle's Avatar
    Oct 2011
    Clinton
    Hills District
    Default Who has the template for the hydraulic clutch into ke70??
    AS title states, PM me
    Clinton
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    You dont need it dude....... I have done this mod 4 times, and never needed it... Just a tape measure, texta for marking, 32mm hole saw on drill, and look carefully......
    I've found it easiest to drill from the inside out once the dash is out. Start with the thread on the ae71 peddle box and drill that, and then fit the peddle box. Bit of grease smeared on the end leaves a good mark where to drill. Then mark the other hole and drill that.
    Drill a small pilot hole for the holesaw in the centre of the clutch slave area, and then drill with the holesaw from the engine bay in and smooth out with a file / die grinder.
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    i put a simple way of doing it in by build thread. i wouldnt bother with templates and stuff
  1. Hydraulic clutch release bearing for T50 gearbox
    By jimmy19650 in forum Technical - Articles
    Last Post: 7th September 2020, 08:26 AM
  2. KE70 CS-X with AE71 drivetrain (4ac, T-50, hydraulic clutch) (Melb)
    By cae-086 in forum Cars for Sale (Toyota Only)
    Last Post: 31st October 2012, 04:32 PM
  3. Hydraulic clutch stuff - ae71 xmember - Brake Pads
    By Gullie in forum Car Parts For Sale
    Last Post: 6th February 2008, 05:58 PM
  4. Cable clutch to hydraulic conversion
    By Aus-spec86 in forum Technical - Questions
    Last Post: 27th January 2008, 10:30 PM
  5. can u adjust hydraulic clutch????
    By EZZE86 in forum Technical - Questions
    Last Post: 27th April 2006, 06:35 PM
