Results 1 to 10 of 11
Thread: GZE oversize crank pulley
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default GZE oversize crank pulley
    Hey ppl I have a alloy oversize crank pulley on my gze that I dont need so I'm looking to swap for a standard gze pulley as I am going to turbo the motor.
    can adjust with cash either way if need be.
    Or $180 neg.
    Located in Sydney
    Pics in my build thread.
    Member filfilfil's Avatar
    Phil
    Just South
    What brand is it?
    Bryan
    Waterford
    Tramore
    Ireland
    Any 16V pulley will suit you going turbo so long as you don't have P/S or A/C so you don't need a GZE pulley.
    May 2010
    Adam
    St George
    Not sure on the brand it looks to be techno toy tuning. I'll check it this arvo and let u know
    May 2010
    Adam
    St George
    Couldn't find and markings on it..does any one want this..
    May 2010
    Adam
    St George
    Bump....price drop...really after a standard 16v pulley
    Veteran Nikkojoe's Avatar
    Tom
    Not that im interested, but to help anyone else out there what size is it?
    165mm will make approx 10/12psi (bigport/smallport charger)
    175mm will make approx 13/15psi
    180mm will make approx 15/melted charger
    170mm and bigger will probably require a smaller idler and possibly modification to water pump pulley
    If you want a standard 16v pulley I have an unused ae82 one (test fitted only) and a few standard gze ones (used)
    May 2010
    Adam
    St George
    Thanks for that.. I'll measure it when I get home..
    tom did u want to pass on a standard 16v pulley?
    May 2010
    Adam
    St George
    It's a 175mm
    May 2010
    Adam
    St George
    Bump
  1. GZE crank pulley
    By Evan in forum Cars or Parts Wanted
    Last Post: 16th February 2009, 08:41 PM
  2. GZE over sized crank pulley
    By samuek in forum Cars or Parts Wanted
    Last Post: 11th August 2008, 05:44 AM
  3. 4agze- what else do i need to install a oversize crank pulley
    By nvy-412 in forum Technical - Questions
    Last Post: 23rd July 2008, 09:35 PM
  4. N/A and GZE crank pulley interchangable???
    By myt-16v in forum Technical - Questions
    Last Post: 26th May 2008, 10:52 PM
  5. crank pulley on GZE and GE
    By samuek in forum Technical - Questions
    Last Post: 7th May 2008, 11:45 PM
