the two yellow ones are coolant temp and oil pressure
Watsup..
So ive been looking for a while and cant find a answer specific to my question. On my ke70 the loom coming out near the booster that runs along the firewall, i need to know what these wires do. At the 6 pin plug it has these wires and so far ive worked out that...
Yellow-Black stripe - temp sensor
Purple - ??
Red-Blue stripe - Reverse lights
Yellow-Green stripe - ??
Red-Blue stripe - Reverse Lights
Can someone confirm this, im probably wrong!! Where do the other purple and yellow wires go/do??
Thanks for the help guys
ok so i guess the yellow-black stripe goes to coolant temp on the head, and the yellow-green stripe goes to oil pressure sender..?
Yellow black is oil pressure, yellow green water temp on the top water outlet to radiator.
Purple not sure, probs 4k specific. On an ae86 or ae71 the 5th wire is usually starter signal, but I'm sure this is not the case on a ke70
where does the oil pressure wire go to the dash? does the oil light come on if theres no pressure?? are the red wires reverse? anyone know what mr purple wire is for
thanks for the help guys
red / blue are reverse lights
Yellow/black - oil pressure
Yellow/green - Temp
Purple - Ignore (nothing important)
Purple is important maaan, it's for the emissions computer...
which I've never been able to find.
and by computer I think it's a mechanical "computer". a speed operated valve.
and that's as far as I cared to look into it.
Fair enough.. I think I'll just trace it back and see where it goes not really bothered with emissions and it was probably something 4k related witch us long gone!!
Can anyone tell me how the oil pressure wire works does it just activate the oil light on low pressure? Does it become useless if I put a oil pressure guage in??
yes and yes. and when you say you pressure, it's like 21kPa max (I think, I vaguely remember seeing a 9kPa one) which is ~3psi. Engine's GONE if that comes on while cornering and revving.
