Page 17 of 21 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 161 to 170 of 209
Thread: Blood Red SR20DET AE86 - My 4th AE86
  1. #161
    Aug 2010
    Adrian
    South
    A picture off the Toyota Aus Facebook page
  2. #162
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Thanks for sharing Adrian
  3. #163
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    I wonder if Toyota Australia had any idea that that is a Nissan donk...
    Current Cars:
  4. #164
    JoJo
    ACT
    Tuggeranong
    I dodged a bit of a bullet on the weekend....
    My intank fuel pump/pickup assembly broke off inside the tank while I was driving. Luckily I was just driving in traffic, and not under boost.
    After getting it back to the yard, Pretty easy to diagnose when you have 0 fuel pressure on the gauge. lol
    After dropping the tank, and pulling out the pickup assembly, its a bit hard to suck fuel with no pump. hahahahahahahhahahahah
    The internal pump holder welds had snapped off the top cover. Pretty strange...
    Anyway, I have a custom modified tank from my Gold AE86 track car (R.I.P) that was made for drift purposes with swirl pot/baffles etc , thats just sitting there waiting to go in to this car. Now seemed like a good chance to install it with a new pickup/pump assembly I made up.
    All back together now. No more fuel smell in the car, fuel pump is quiet again, and the drift tank is now in its home.....
  5. #165
    Robbo
    Gippsland
    Needs moah updates
    Current Cars:
  6. #166
    JoJo
    ACT
    Tuggeranong
    I agree..... Who's in charge here?
  7. #167
    JoJo
    ACT
    Tuggeranong
    Ok, well it's been ucking ages since I've done an update. I dont have a camera either, so limited to just text for now....
    In the last few months I've fixed up alot of things about the car I was not happy with....
    Firstly, I changed the turbo as the previous one was howling at high revs. I have fitted up another S13 T25, but this turbo seems a bit down on power, but at least its balanced right..... Its great as you are pretty much always boosting , but runs out of puff up high.
    I have also stripped out the front interior, carpet etc, so the whole car is stripped out.... (had front half custom interior before)... After pulling all the interior out, I wanted to fix up the transmission tunnel and shifter area. The craftsmanship was not up to my standard...... I went and cut the trans tunnel out of a S14, and I have welded it into the car. came up well and can use the S14 shifter boot etc..........
    Next job was to make my dual rear caliper setup for the rear and install a hydro E-brake. I run a modified Borgwarner VS commodore diff setup and brakes (custom billet axles, mini spool, 4:11 c&p). Now, these brakes are super easy to make dual caliper setups on.... Simply, you get a second pair of the stock caliper brackets, and cut both sets in half vertically, and weld a left and a right side together, giving you 2 lots of mounts ...... I have used a second set of stock VS calipers for the hydro too, and they seem to work very well...... Cost me $50 for the VS calipers and second brackets , and did the work myself. Hydro E-brake is welded to the trans tunnel, with remote reservoir in the engine bay.....
    LEFT/BEFORE - RIGHT/AFTER:
    ^^ I forgot to tighten the fitting on the reservior when I first filled it and it leaked some brake fulid onto the paint :/ Oh well.......
    Visually on the exterior, I have now painted the front and rear bars black..... The rear bar has been changed to a Vertex bar, as I smashed the red Origin rear bar to pieces :/
    I have also changed the exhaust. I removed the CAT and rear muffler, and fitted up some nice blast pipes.... Sounds like a real tractor now, but tone is good.
    Now, I have been running the S13 front end suspension for 2 years now, and I have not got it handling like it should despite my efforts to make it work well..... So, I have pulled out all the S13 front gear and S13 castor mount setup etc...... The rack I had had bad play and knocking too, which needed replacing...
    I am reverting back to Toyota geometry.... I have installed my GReddy suspension setup front and rear.....
    I have replaced everything up front. Fitted New Superpro rack bushes, new RA60 tierods, new RA60 rackends, AJPS lock spacer, Power steering arms, Whiteline adjustable swaybar, T3 NCRA's (had to use NRCA's so the caliper would clear the swaybar on full lock, XT130 LCA's with new ball joints and new poly LCA bushes, low kms KE70 rack, new caster rod bushes and fitted up a Whiteline strut brace to replace the crappy ebay S13 drilled out one......
    The car feels like a different car....... 10 fold better.... I am convinced S13 gear is shit in 86's now......
    I will try to get some pics up soon for those following.....
  8. #168
    Veteran drift kid's Avatar
    Glossodia
    Looks heaps better now imo, good work, glad to hear you went back to 86 front end too, good decision, overall the car is coming along real well dude
  9. #169
    JoJo
    ACT
    Tuggeranong
    Thanks Benny, yeah, the car is always gettiing improved....
    Next task is to get a decent turbo for it....
  10. #170
    JoJo
    ACT
    Tuggeranong
    I entered the Cooma Hillclimb on the weekend... They hold it on a closed off public road that goes up Mt Gladstone, just out of Cooma, NSW.
    My times were average, but I had really old semi's and getting traction was an issue...
    There were 3 AE86's that came from Canberra. Steve Pembrey's 2GR V6 AE86, Airocobra's (Bob) 16v Bigport track AE86 and my car.... All 3 cars are red
    This was NOT a drift event, but Steve being Steve, he was running the wall on that last turn....
    Here is a video or two....
    And a few pics....
    This was a Twincharged 4A Clubman. The motor is a unopened 4AGZE motor It is claimed to be making 270rwkw
  1. AE86 Genuine J BLood Front Bar, AE86 Copy Ducktail. SA.
    By dreny... in forum Car Parts For Sale
    Last Post: 16th August 2010, 04:42 PM
  2. AE86 J-Blood Guards
    Last Post: 28th October 2009, 05:11 PM
  3. sr20det red top stripped to rebuild
    By aussyboyz in forum Car Parts For Sale
    Last Post: 28th September 2009, 12:37 PM
  4. blood red turbo trueno....
    By Cvet in forum Cars for Sale (Toyota Only)
    Last Post: 29th July 2008, 12:27 AM
  5. Intense's Blood Red Panda
    By intense in forum AE86 Owners Forums
    Last Post: 16th August 2007, 10:43 AM
