Results 1 to 10 of 13
Thread: Ke70 left field engine conversion
    Member SR_andy's Avatar
    Andrew
    Heritage park
    Default Ke70 left field engine conversion
    Ok so no flames straight away. Had a random thought, now we all know how expensive a small port 4ag swap is getting so I had a thought a ca18de conversion. 1.8l so a little more torque then a 4age, cheap as chips, good aftermarket support and with a ca bell on an rb box shifter should be in factory hole.
    I know we all love 4Age and some of us hate datsun motors but it's just a thought and maybe a discussion is on the table....
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Speaking of left field conversions, but has anyone thought about the new Ford Eco-boost engines? 4cyl, 2L, turbo, 205kw, 380NM torque from factory, Twin-Independent Variable Cam Timing (Ti-VCT).....
    Built to have the performance of a V6, but with less fuel consumption.....
    Junior Member filfrederick's Avatar
    Jan 2010
    Phil
    Taringa
    I have always wanted an NA FJ20 in a ke, heaps of torque and will rev forever!
    Veteran Skylar's Avatar
    Ken
    Some modern motor would be cool but cost is prohibitive when th suggested motor is a ca18de. That motor, or a vq35, alloytec, xgr-fse would be cool. I know the Vq is pretty standalone but I don't about the rest and will probably need a sandalone ecu.
    I've always wanted to do vg30de or ecotec motor.
    I know ca18 is dirt cheap but if you're going to the effort of a Nissan motorswap, mod the crossmember to take standard ca mounts and brackets so that if you get sick of it, you can bolt in a sr20de if you find one cheap enough. gives you the option of rb20 if you're that way inclined.
    Elite rthy's Avatar
    Leo
    Tulla
    Too many things to consider and custom fab work (may work out if you do all the work yourself).
    with the 4age, pretty much a bolt in job.
    Ie.
    Custom Engine crossmember and mounts
    Custom Gearbox Crossmember and mounts
    Custom Tailshaft
    Mod tranny tunnel?
    Diff (more power, maybe need to rack off the tiny borgy for something stronger)
    Brakes (more power, more weight, tiny gridlocks)
    Suspension
    Custom Engine loom
    Custom Radiator
    30kw club
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    I see the merit in a CA conversion.
    Rebuild is cheap. Smash the compression up and clean out the head.
    More capacity. Can you itb that shit?
    Yeah do it.
    quit hatin get bakin!
    Andrew
    Heritage park
    I would imagine you could run itbs with a adaptor and some management pretty easy. Best thing for me about the swap is that
    It's already rwd so nonfucking around with water pumps and coolant hoses. Plus they are 98kw standard so I would imagine would drive pretty similar to a small port with a bit more torque...
    Joe
    NT
    Nightcliff
    That's what I would have figured. I think it would be an awesome comparison. 16v 4A, 20v 4A, CA Ke.
    What is an NA CA's compression, weight, and price for rebuild?
    If I was doing another conversion I'd be looking at an autech sr20de+t setup...high comp turbo glory
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    I have an autech in my ke and its great with the high comp. I considered the possibility of a small turbo and putting a bit of boost through it oneday but can't justify the cost when I could sell my package and buy a det cheaper. It would be awesome though if money wasn't a issue
  1. Ke70 engine conversion questions? What to get? Where to get it done?Nsw
    By northernbeaches in forum Technical - Questions
    Last Post: 6th January 2013, 09:34 PM
  2. things left over from my conversion
    By pen15 in forum Car Parts For Sale
    Last Post: 16th April 2012, 02:24 PM
  3. Replies: 19
    Last Post: 6th March 2012, 09:45 AM
  4. engine conversion package for ke70 4age sr ca and so on
    By swcustoms in forum Cars or Parts Wanted
    Last Post: 6th April 2011, 09:56 PM
  5. wtb 4age engine conversion for ke70
    By sld sho in forum Cars or Parts Wanted
    Last Post: 2nd April 2011, 12:54 PM
