My routing for the heater system is as follows:
1. Bypass pipe from top outlet at front of motor,
goes to
2. a tee piece coming off the remote thermostat (to tickle the thermostat and feed too)
goes to
3. one side of heater core (this hose also has a Tee piece to feed the turbo)
comes out other side of heater core and goes to heater tap,
4. from heater tap, goes to water outlet on the back of the head. (this hose has a Tee piece to return from the turbo)......
Should be right............. ??????????????
