Results 21 to 27 of 27
Thread: Introducing "Cherry"
Threaded View
    Senior Member Mad RS's Avatar
    Queensland
    Wynnum
    Default Introducing "Cherry"- For Sale now
    Hi Everyone,
    Let me introduce "Cherry" (aka Cherry Blossom). There is a Japanese saying that goes something like "Even though each cherry blossom is different, they are all perfect". This is how I see Her.
    I purchased this car off 86sp (Thanks heaps mate, she will be well looked after) so she is bought not built but if I was to build a hatchi I would hope that it would turn out something like this.
    Here is a list of all the fruit that came with the car:
    ENGINE -
    Smallport 4AGZE
    Cometic metal headgasket
    ARP headstuds
    TODA 264/256, 7.9mm lift cams
    New timing belt, cam and crank seals
    Garret 2860RS turbo
    Custom stainless turbo manifold
    3" exhaust, dump to rear muffler
    Turbosmart boost controller
    Cut and shut inlet manifold
    550cc injectors (from an Evo?)
    VL turbo fuel pump
    Tomei FPR
    Custom ignition leads
    Bosch coils (mounted inside cabin)
    Microtech LT10s computer
    K&N air filter
    Turbosmart duel port BOV
    HKS oil cooler kit (with filter relocator)
    Custom catch can
    GTIR front mount intercooler with stainless piping
    Alloy radiator with thermo
    DRIVELINE -
    NPC billet flyhweel
    NPC custom clutch (using 4G63 pressure plate)
    W57 gearbox
    Custom bell housing
    Hardy Spicer 1 piece tailshaft
    Hilux diff with shimmed up stock LSD (4.11 ratio)
    SUSPENSION -
    Full Shockworks Coilover suspension
    Cusco front strut brace
    Front and rear Whiteline adjustable swaybars
    Apex engineering adjustable 4 link
    Whiteline adjustable panhard rod
    BRAKES -
    AJPS Civic/RX7 front brake kit
    EBC slotted discs
    Greenstuff Pads
    R31 rear calipers
    Near new rotors and pads
    WHEELS AND TYRES -
    Dynamic D Steel wheels in 15x8 +0
    Federal 595RSR 205/50/15 all round
    INTERIOR -
    4 point welded in roll cage (Front only)
    AJPS Harness bar
    Sparco Sprint fixed back seats
    Custom rails
    Sparco 3" harnesses
    JustJap steering wheel
    Pivot tacho with built in shift light
    APEXi copy gauges - oil pressure and water temp
    Battery relocated to hatch
    Fire extinguisher
    AJPS dash mat
    EXTERIOR -
    Full respray in Mazda red
    Rolled guards all round
    JDM Whiteline taillights
    I'll try my best to keep people informed of any new mods that I may add. At the moment I will be just refining what I have.
    And here are some recent photo's that I have taken:
Name:	Three Quarter a.jpg
ID:	30748   Click image for larger version.
ID:	30749   Click image for larger version.
    Run what ya brung...............and make damn sure ya brung enough!!!!
  2. T-18 13 4 spoke steel rim dimensions, pretty please? Cherry on top?
    By floody in forum Technical - Rims & Tyres
    Last Post: 24th July 2011, 09:52 PM
  3. Wanted 13 or 14 Watanabes 6 6.5 or 7 :-)
  4. """"rear springs and dildo shifters""""
  5. WTD: 15 SSR MESHIES 7.5 or 8 or 8.8 around ZERO offset!
    By ludachris in forum Cars or Parts Wanted
    Last Post: 28th January 2009, 10:48 PM
