Results 1 to 6 of 6
Thread: JDM loom vs ADM loom
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    hey guys,
    I just got a JDM 16v 4AGE, with no loom or ecu, and was wondering what my options are.
    What loom do i need?
    Is there a differance between a JDM and ADM loom?
    And ecu's, what do i need? Aus or Jap?
    can i just run a microtech and not worry about looms etc?
    any ideas?
    much appriciated,
    J
    Senior Member Medicine_Man's Avatar
    Justin
    North
    The motors are pretty much the same, Just use the correct wiring harness to suit the ECU and you will be fine.
    You can of course create your own wiring harness and go the aftermarket ECU option, Depends how much money you have to spend..
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    Veteran Nikkojoe's Avatar
    Tom
    Either ecu will work on either wiring harness.
    I've used a JDM ecu on an ADM loom.
    I'm currently using an ADM ecu on a JDM loom Just need to give injectors power
    Justin
    North
    You have to take in to consideration too that there are MAP and AFM versions of the 4AGE..
    Like I said, Wiring harness to suit the ECU..
    Tom
    <div class='quotetop'>QUOTE (Medicine_Man @ Mar 29 2008, 08:54 PM) </div>
    Yeah forgot to add Bigport Map in my post
    Oldschool Member
    Mar 2008
    if you got a 4age engine, then you will need a 4age loom or build aftermarket one. Either way, you will also need to make amendments to your AE86 dash loom as it doesn't have idle up, circuit-open-relay and few other parts for EFI. This means you be running few extra wires etc. If you want less fuss and more reliablity, go with the JDM 4age efi loom, inside out...plug and play.
  1. JDM loom in ADM shell
    By dtour in forum Technical - Questions
    Last Post: 13th January 2011, 02:55 PM
  2. Syd jdm 4age/loom/ecu/adm t50
    By corknose in forum Car Parts For Sale
    Last Post: 2nd August 2010, 05:14 PM
  3. JDM loom -> ADM ECU
    By Sparkle86 in forum Technical - Questions
    Last Post: 27th September 2007, 11:37 PM
  4. Swaping ADM Wiring Loom with JDM Loom
    By joshcris in forum Technical - Questions
    Last Post: 20th September 2007, 03:18 PM
  5. ADM ECU on a JDM loom
    By Brenton in forum Technical - Questions
    Last Post: 15th May 2007, 05:41 PM
