Results 1 to 10 of 10
Thread: Adm AE86 for sale plus parts and spares - time to sell, the love is gone.
    Bullcreek
    Default Adm AE86 for sale plus parts and spares - time to sell, the love is gone.
    SOLD SOLD SOLD PLSCLOSE
    I have a 1983 ADM AE86 for sale in Perth WA.
    The car is not running and will need the following work to be drivable...
    Fit tailshaft, exhaust, and tune.
    Price: as is with all parts $13000, $15000 running
    Inventory And vehicle spec is as follows.
    For Sale - 1983 Toyota Sprinter AE-086 SOLD PENDING PAYMENT
    Drive Train
    Engine - Blacktop 4age
    T3 trumpets -silver
    New Toyota rwd water pump and housing
    New AE82 thermostat housing
    Trd thermostat
    Trd oil cap
    Trd 0.8mmhead gasket
    New Toyota timing belt
    New rwd front pulley - machined down to suit 20v
    RS Chita waterline kit
    Clutch and Gearbox
    Std blacktop Flywheel
    TRD Sports clutch plate
    Brand new TRD pressure plate
    T50 JDM Gearbox
    TRD Short Shift with leather TRD gearknob.
    Differential
    Jdm tail shaft, rear half serviced by veem
    T Series Kouki JDM Diff 4.3 final drive
    TRD 1.5 way
    Cooling
    PermaCool Oil Filter Relocation Kit with thermostat and 250HP Cooling Core.
    Koyo Aluminium Radiator, 82C thermo switch and 14 and 12 inch thermofans.
    Electronics
    Motec M4 with Datalogging laptop for tuning comes with car.
    Engine Loom stripped of erroneous parts.
    1nz coil packs
    Sealed Battery mounted low and in centre of car with isolation switch
    Fuel System
    Walbro 400HP Intank Fuel Pump
    JDM baffled Fuel Tank
    Steering, Suspension and Bracing
    Quaife 2.5 turn rack - New tie rod ends, New boots
    Front Strut brace
    Carbon rear strut brace
    Nagasia Auto under fender braces
    Whiteline 25mm RCA’s
    Custom Shorted front coilovers as seen on Club 4ag website( shortened, steel sleeve welded on etc)
    Tokico HTS 102 shocks front (infinitely adjustable)h
    8KG AJPS front springs
    Tokico HTS 102 shocks rear (infinitely adjustable)
    6KG AJPS rear Springs
    Std Front swaybar with adjustable links
    Whiteline Adjustable Rear Swaybar.
    T3 Camber tops
    Whiteline Panhard Rod.
    Wheels
    Konig Rewinds 14 x 7 -8 with new Yokohama C Drive Tyres Front and New Good year Eagle NCT Rear
    Project u Lightweight wheel nuts.
    Brakes
    Cusco Master Cylinder Support Bracket
    JDM proportioning valve
    Braided ADR approved lines throughout
    Front -T3 Big Brake Kit
    · 280mm Cross drilled and slotted rotors
    · Wilwood 4 Piston Dynalite Calipers
    · Some sort of race pad.
    Rear JDM Disks
    Interior
    Rear Stripped
    Older Style Velo GP90 Seat
    Wisteria Seat rails adjustable front and back , left and right.
    JDM digidash
    100mm adjustable length steering boss extension.
    JDM Accelerator Pedal texture powdercoated
    Aftermarket steering wheel
    Body
    Metallic blue with some minor scratches
    Rust in rear arches, near fuel filler and in boot area.
    Spares / Parts List
    Zenki Trueno front bar
    Trueno headlights with actuators
    TRD style side skirts and no name front lip SOLD PENDING PAYMENT
    MX13 F Series Diff, with RT142 disk conversion with NEW RT142 disks with AE86 mounts.
    RS200 Altezza Torsen 4.3 Final Drive
    Vertex copy Streeter front bar
    Vertex copy side skirts
    Vertex copy rear bar
    Frp ducktail
    Silvertop 4AGE
    Blacktop 4age manual ecu
    Fwd 4age distributor relocation kit
    Full TODA 4-2-1 exhaust to suit ae86 with 4age SOLD PENDING PAYMENT
    Full 4-1 Exhaust to Suit AE86 4AGE
    Blacktop FWD extractors
    Tune Agent Rosejointed 4 link - some surface rust
    S14a T28 BB turbo
    Front JDM Calipers, and Disks
    Koni Rear Shocks
    Noltec Camber tops
    Front coilover struts
    6KG front coilover springs
    4 KG rear springs
    Bond Roll Bars 6 point Roll cage with harness bars and side intrusion bars.
    6 x MA61 Rims powder coated white
    4 x 14x6 mesh wheels +25 with average tyres
    Set ADM Front lights
    Set ADM Front indicators
    Set ADM rear lights and centre garnish
    T3 Tow hook
    T3 Traction Brackets
    Aircond lines compressor and heat exchanger.
    Whiteline strut brace SOLD PENDING PAYMENT
    Tailshaft rear half
    Call Ben on 0437900511 outside of business hours or 0417900501 during business hours
    I am keen to sell pics to follow.
    Bullcreek
    Pics
ID:	25681   Click image for larger version.
ID:	25682   Click image for larger version.
ID:	25683   Click image for larger version.
ID:	25684   Click image for larger version.
    Veteran McLEVIN's Avatar
    Nov 2010
    how much you want for this lot if your interested in parting out?
    Cooling
    Koyo Aluminium , 82C thermo switch and 14 and 12 inch thermofans.
    MOPAR or no car!
    Bullcreek
    Hi McLevin Not interested in parting out at this stage if I do you have dibs
    Nov 2010
    figured as much GL!
    MOPAR or no car!
    Junior Member white_sandshoe's Avatar
    May 2010
    Garnett
    Willing to sell any of the spares separate?
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Yeah, interested in some of the spares if willing to sell seperate.....
    F series diff
    ADM Front lights
    Senior Member Prime86's Avatar
    Sep 2009
    Brad
    Perth hills
    Hey Ben
    If you decide to separate some of the spares I would be interested in a few items.
    Brad
    Veteran Nikkojoe's Avatar
    Tom
    Same, interested in F-series diff(S) (including the altezza one if it includes the housing too) and t28bb pending condition
    Bullcreek
    Updated
  1. MELB adm ae86 rolling shell + spares
    By burcoty in forum Cars for Sale (Toyota Only)
    Last Post: 1st September 2011, 01:14 AM
  2. Spares for sell: 14's, distributors, bushes etc.
    By blair in forum Car Parts For Sale
    Last Post: 5th July 2011, 02:29 PM
  3. sold car, now time to sell the parts, tas
    By brad in forum Car Parts For Sale
    Last Post: 27th June 2009, 11:45 AM
  4. time to clear ALL my spares, fc calipers, RCA's
    By slide86 in forum Car Parts For Sale
    Last Post: 7th June 2008, 12:18 AM
